04-15-2025 12:24 AM
Hi!
I have and HP Synergy blade chassis with HPE Virtual Connect SE 32Gb with MPO to 4x LC Breakout Multi-Mode Fiber Optic Cable.
During testing of different hardware prior to going into production with new MDS switches, I found problem with this combination.
I have connected the HP VC and configured only two of four MPO uplinks as 16Gb, connected 2 Optic Cables to 2 Cisco 64Gb SFP, the ports are in up state and negotiate as 16Gb, If I change in the HP VC the configuration of the ports to 32Gb, I can see in the MDS switch port status as notConnected.
What could be the cause of this behavior?
Solved! Go to Solution.
04-17-2025 08:07 AM
HPE is aware of this issue. The issue comes down to the 100Gb QSFP to quad 32Gb SFPs have a problem. While negotiating 32Gb FC speeds, the HPE SFP suddenly reduces it's speed to 16Gb when communicating back to the Cisco 64Gb interfaces. This is caused by the HPE hardware expecting a Training Complete before it successfully finishes the negotiation.
The MDS isn't seeing any primatives or FC data on the line. You can use slot X show hardware internal fcmac port Y port-logs for interface fcX/Y and see that SNR:0.0 which indicates the MDS isn't receiving signal. In this particular case we can see the fibre channel training frames agreed on 32Gb, but then the remote side droped to 16Gb.
`slot 3 show hardware internal fcmac port 1 port-logs`
========= FCP Port#1 Internal Port platform Log ==========
MMDDYY HHMMSS usecs Event DATA
041525 144012 314194 SERDES_RX_STATE ST:0x4FF2207 DP:0x1 S:1 C:1 P:0 LEQ:0 VGA:25 ATT:2 SNR:0.0 FBF:0.00 1007:0x5D6F 1006:0xFE004804
041525 144012 313839 TTS_SYNC Pass:1 val:0x104 RX:32G TX:16G TF.CS 0x L[08,70] R[C0,40]
041525 144012 282959 RX_LANE_ENABLE Lane:0x31 SN:0x835 TX:0xC RX:0x10
041525 144012 282696 SERDES_DELAY Reg val:4
041525 144012 282271 SERDES_RX_SPEED 32G
041525 144012 282271 SERDES_TTS_RX 32G SN:0x835 Lane:0x11
This is an example of the Signal to Noise Ration being zero.
041525 144012 609444 SERDES_RX_DFE 0.00,0.00,0.00,2.00,0.00,0.00,0.00,0.00,0.00,0.00,0.00,0.00,0.00,0.00,0.00,0.00
041525 144012 609190 SERDES_RX_STATE ST:0x4FF2207 DP:0x1 S:1 C:1 P:0 LEQ:0 VGA:25 ATT:2 SNR:0.0 FBF:0.00 1007:0x5D6F 1006:0xFE006835
041525 144012 608827 TTS_SYNC Pass:1 val:0x104 RX:32G TX:32G TF.CS 0x L[C8,70] R[C0,40]
041525 144012 578502 SERDES_RX_DFE 0.00,0.00,0.00,2.00,0.00,0.00,0.00,0.00,0.00,0.00,0.00,0.00,0.00,0.00,0.00,0.00
041525 144012 578178 SERDES_RX_STATE ST:0x4FF2207 DP:0x1 S:1 C:1 P:0 LEQ:0 VGA:25 ATT:2 SNR:0.0 FBF:0.00 1007:0x5D6F 1006:0xFE00681B
041525 144012 577809 TTS_SYNC Pass:1 val:0x104 RX:32G TX:32G TF.CS 0x L[C8,70] R[C0,40]
041525 144012 547505 SERDES_RX_DFE 0.00,0.00,0.00,2.00,0.00,0.00,0.00,0.00,0.00,0.00,0.00,0.00,0.00,0.00,0.00,0.00
041525 144012 547181 SERDES_RX_STATE ST:0x4FF2207 DP:0x1 S:1 C:1 P:0 LEQ:0 VGA:25 ATT:2 SNR:0.0 FBF:0.00 1007:0x5D6F 1006:0xFE006802
041525 144012 546810 TTS_SYNC Pass:1 val:0x104 RX:32G TX:32G TF.CS 0x L[C8,70] R[C0,40]
The recommendation is to Open a case with HPE and ask them for assistance. You can also open a case with Cisco TAC to request assistance.
04-15-2025 01:41 AM
- Check logs on the MDS after trying to make an intended connection (or configuration) ,
M.
04-15-2025 02:15 AM
Thanks Marce, a colleague is working with HP support to analyze the cause of the problem.
I will report the cause when we have an answer.
04-17-2025 08:07 AM
