EISL / TE Port between MDS 9216 and 9124 ?
Dear All ,
I have a MDS 9216 connected to an MDS 9124 . The connected ports are showing as E Ports and not TE ports .
What do I need to do to get them in TE mode of operation .
MDS 9126  fc1/2 --------------------- fc 1/3 MDS 9124
MDS9216# sh int fc 1/2
fc1/2 is up
    Hardware is Fibre Channel, SFP is short wave laser w/o OFC (SN)
    Port WWN is 20:02:00:0d:ec:0c:78:00
    Peer port WWN is 20:03:00:0d:ec:57:cd:00
    Admin port mode is auto, trunk mode is auto
    Port mode is E, FCID is 0x9a0001
    Port vsan is 1
    Speed is 2 Gbps
    Transmit B2B Credit is 16
    Receive B2B Credit is 255
    Receive data field Size is 2112
    Beacon is turned off
    5 minutes input rate 144 bits/sec, 18 bytes/sec, 0 frames/sec
    5 minutes output rate 272 bits/sec, 34 bytes/sec, 0 frames/sec
      7751 frames input, 384692 bytes
        0 discards, 0 errors
        0 CRC,  0 unknown class
        0 too long, 0 too short
      7737 frames output, 596996 bytes
      0 input OLS, 1 LRR, 0 NOS, 16 loop inits
      3 output OLS, 3 LRR, 0 NOS, 4 loop inits
      255 receive B2B credit remaining
      16 transmit B2B credit remaining
Software
  BIOS:      version 1.1.0
  loader:    version 1.2(2)
  kickstart: version 2.1(1b)
  system:    version 2.1(1b)
MDS9124# sh int fc 1/3
fc1/3 is up
    Port WWN is 20:03:00:0d:ec:57:cd:00
    Peer port WWN is 20:02:00:0d:ec:0c:78:00
    snmp link state traps are enabled
    Port mode is E
    Port vsan is 1
    Speed is 2 Gbps
    Rate mode is dedicated
    Transmit B2B Credit is 255
    Receive B2B Credit is 16
    5 minutes input rate 296 bits/sec, 37 bytes/sec, 0 frames/sec
    5 minutes output rate 120 bits/sec, 15 bytes/sec, 0 frames/sec
      8921 frames input, 732652 bytes
      8930 frames output, 421396 bytes
      5 input OLS, 6 LRR, 0 NOS, 8 loop inits
      5 output OLS, 2 LRR, 4 NOS, 5 loop inits
      16 receive B2B credit remaining
      255 transmit B2B credit remaining
      254 low priority transmit B2B credit remaining
    Interface last changed at Wed May  9 03:32:24 2012
Software
  BIOS:      version 1.0.12
  kickstart: version 3.2(3)
  system:    version 3.2(3)
Regards ,
Vikas Srivastava
both the sides are default to trunk mode auto. In this case there will be no trunking, just regular ISL.
Check Table 12-2
http://www.cisco.com/en/US/docs/storage/san_switches/mds9000/sw/rel_2_x/san-os/configuration/guide/trnk.html#wpxref31164
Can you configure one side to 'switchport trunk mode on'  under the FC port and check if you can get the link up as TE port?
Thanks, Vin.
vdsudame
ie is this a new install or you have more vsans defined on the mds switches which you have allowed on the trunk ? what does the trunk config look like ?
from both switches, please get,
show vsan
show run int fc1/2(3)
Thanks, Vin.
Hi Vin ,
Heres the output :
Please note that on both the interfaces i have used the commands "switchport trunk allowed vsan all" but its not showing in the output here .
ICE-MDS9124# sh running-config int fc 1/3
version 3.2(3)
interface fc1/3
  port-license acquire
ICE-MDS9216# sh run int fc 1/2
version 2.1(1b)
interface fc1/2
  no shutdown
ICE-MDS9216# sh vsan
vsan 1 information
         name:VSAN0001  state:active
         interoperability mode:default
         loadbalancing:src-id/dst-id/oxid
         operational state:up
vsan 500 information
         name:VSAN0500  state:active
vsan 600 information
         name:VSAN0600  state:active
vsan 4094:isolated_vsan
ICE-MDS9124# sh vsan
vsan 1 information
Check Table 12-2
Thanks, Vin.
Thanks Vin , Configuring 'switchport trunk mode on' got as I wanted it to be ...
