Cisco 9513 and Cisco 9148 - Fabric Merger
Hi All,
I am currently in the process of merging fabrics;
The main SAN switch is the MDS9513 with an active zone configuration since 2011, the client has furthermore went ahead and bought a 9148, which currently doesn't have any zone config.
I have prepared the ports as follows (lets focus on one port to simplify matters):
Cisco 9148
MTA-9148-FA# show interface fc1/45 br
Interface  Vsan   Admin  Admin   Status       SFP    Oper  Oper   Port
                  Mode   Trunk                       Mode  Speed  Channel
                         Mode                              (Gbps)
fc1/45     20     E      on      down         swl    --    --     --
Cisco 9513
TECFABA# show interface fc11/31 br
                         Mode                              (Gbps)
fc11/31    20     E      on      down         swl    --    --     --
No physical link is connected as yet because I am afraid the Main SAN Switch will go into segmentation.
16 Replies 16
Walter Dey
I assume you have multiple vsan's; therefore your isl's between the 2 MDS would be a trunking E port, allowing a range of vsan tagged frames over the ISL.
Regarding fabric merge, see eg. the recent discussion
https://supportforums.cisco.com/discussion/12916986/merging-two-fabrics
Hi Walter,
Thank you for the prompt feedback.
My fear is the main SAN switch that is currently in production going into a segmented mode, meaning that the Fabric will lock, and the small 9148 taking over , How can I avoid that.
Due to the fact, that the new 9148 doesn't have a active zoneset, you should not have a problem.
The zonesets for any vsan's which exists on both switches will be copied from the 9513 to the 9148.
What do you mean by fabric lock ? do you run enhanced zoning ?
Walter.
Thank you Walter,
I have the change logged for tonight, I will update you sometime tomorrow:
Just one more question, This is the first time I will be doing as such, what are the results?
How will I complete the zoning for devices connected on the Subordinate Switch (The new 9148)?
Please do a backup of the config on the 9513 (show running or show startup configuration) before you change anything.
And as I said, the ISL ports should TE not E !
I assume you do pwwn based zoning ? therefore most likely you just have to add additional zones for devices connected to the 9148; and them to the zoneset; finally activate this zoneset.
see eg.
http://www.cisco.com/en/US/docs/storage/san_switches/mds9000/sw/san-os/quick/guide/qcg_zones.html
Good luck !
Walter.
Hi Walter,
These are are the options I have:
TECFABB(config-if)# switchport mode
E      F      FL     Fx     NP     SD     ST     auto
As shown above there's no TE.
I have set the ports to E and activated trunking on all ports.
Yes, that's it !
I think in the show interface fc ... you will see it.
Hi Walter,
The change was completed successfully, however I encountered a few errors which I did not understand.
The plan was to establish 4* ISLs per Fabric, however yesterday I only managed to create only 1* ISL per fabric, please see interfaces as of today:
MDS9500 (The Principal Switch)
TECFABA# show interface br | Grep E
fc1/7      1      E      on      trunking     lwcr  TE     4      --
fc1/31     1      E      on      trunking     lwcr  TE     4      --
fc1/37     1      E      on      trunking     lwcr  TE     4      --
fc1/43     1      E      on      trunking     lwcr  TE     4      --
fc5/1      2      E      on      trunking     lwcr  TE     4      --
fc5/7      2      E      on      trunking     lwcr  TE     4      --
fc5/34     2      E      on      trunking     lwcr  TE     4      --
fc6/1      2      E      on      trunking     lwcr  TE     4      --
fc6/13     20     E      on      errDisabled  swl    --    --     --
fc11/31    20     E      on      trunking     swl   TE     8      --
The port in question above is fc6/13, it gave me the errDisabled after we connected the cables.
9148 (The Subordinate Switch)
MTA-9148-FA# show interface br | grep E
fc1/45     1      E      on      down         swl    --    --     --
fc1/46     1      E      on      down         swl    --    --     --
fc1/47     1      E      on      down         swl    --    --     --
fc1/48     1      E      on      trunking     swl   TE     8      --
Please help I still need to establish 3* more per fabric.
Can you tell me which 4 physical interfaces on 9513 and 9148 are used for ISL;
On your initial post: fc 1/45 (9148) and fc 11/31 (9513) both are in VSAN 20;
In your latest post, fc 1/45 is in VSAN 1 ???
Are you sure that the fc interfaces on both switches are in the same port vsan ?
Hi Walter,
I am sorry for the confusion,
The ports are on VSAN 1 on the MDS 9148 and on VSAN 20 on the 9513.
Please find the 4 * ISL ports below (TECFABA = 9513):
TECFABA# show interface br | grep E
fc5/39     20     E      on      errDisabled  swl    --    --     --
fc6/37     20     E      on      errDisabled  swl    --    --     --
As you can see from the dumps above. I keep on getting the same error on the ISL ports... I have suspended VSAN 20 on the 9148.
Furthermore, should I enable VSAN 20 on the 9148 and restart the fcdomain so that is can be active ? and then re-configure the ISL to VSAN 20?
Which vsan's do you want on both MDS ?
You have to create vsan 20 on the 9148, and put all then interfaces fc1/45-48 into vsan 20; otherwise the ISL will not come up ?
Hi Walter,
As suggested, I have activated VSAN 20 on the 9148s, please see below:
MTA-9148-FB# show interface br | grep E
fc1/46     20     E      on      down         swl    --    --     --
fc1/47     20     E      on      down         swl    --    --     --
fc1/48     20     E      on      trunking     swl   TE     8      --
I still see the same error on some ports on TECFABA and TECFABB (9513s)
TECFABB# show interface br | grep E
fc1/1      20     E      on      trunking     swl   TE     8      --
fc11/31    20     E      on      notConnected swl    --    --     --
However I see that fc11/31 on TECFABA has changed to not connected meaning that the cable is having issues. I will replace the cables and monitor.
The issue at hand is the errDisabled port statuses I see, How can I resolve that?
Do I understand this correctly: one of the 4 ISL is up ?
Regarding error disable: Please post
show interface fc ....
show port internal event-history interface fc ...
show logging logfile
http://www.cisco.com/c/en/us/td/docs/storage/san_switches/mds9000/sw/rel_2_x/troubleshooting/guide/ts_guide/ts_port.html#wp32458
Hi Walter,
2* ISL are up on each Fabric.
Using the "show port internal event-history interface fc5/39" and "show logging logfile" I could see that the error was caused by the transceiver not being 8GB. I am working on the Client getting more 8GB SFPs.
