08-05-2015 08:57 AM
I have reset the 9148 SAN swithc back to factory defaults, when I try to enable the FC ports I get: no Enabled FC ports.
License looks correct, 32 ports enabled
any other ideas?
08-05-2015 09:06 AM
according to your picture the switch is in NPV mode, typically when you reset to factor defaults (write erase and then reload) ..it should be in normal "switched" mode ..not NPV for sure.
08-05-2015 10:27 AM
08-05-2015 10:36 AM
port licenses installed ? Can you post output from "sh int br"
08-05-2015 10:43 AM
BCDC91481U45B# sh int br
Interface Vsan Admin Admin Status SFP Oper Oper Port
Mode Trunk Mode Speed Channel
Mode (Gbps)
fc1/1 1 auto on down swl -- --
fc1/2 1 auto on down swl -- --
fc1/3 1 auto on down swl -- --
fc1/4 1 auto on down swl -- --
fc1/5 1 auto on down swl -- --
fc1/6 1 auto on down swl -- --
fc1/7 1 auto on down swl -- --
fc1/8 1 auto on down swl -- --
fc1/9 1 auto on down swl -- --
fc1/10 1 auto on down swl -- --
fc1/11 1 auto on down swl -- --
fc1/12 1 auto on down swl -- --
fc1/13 1 auto on down swl -- --
fc1/14 1 auto on down swl -- --
fc1/15 1 auto on down swl -- --
fc1/16 1 auto on down swl -- --
fc1/17 1 auto on down swl -- --
fc1/18 1 auto on down swl -- --
fc1/19 1 auto on down swl -- --
fc1/20 1 auto on down swl -- --
fc1/21 1 auto on down swl -- --
fc1/22 1 auto on down swl -- --
fc1/23 1 auto on down swl -- --
fc1/24 1 auto on down swl -- --
fc1/25 1 auto on down swl -- --
fc1/26 1 auto on down swl -- --
fc1/27 1 auto on down swl -- --
fc1/28 1 auto on down swl -- --
fc1/29 1 auto on down swl -- --
fc1/30 1 auto on down swl -- --
fc1/31 1 auto on sfpAbsent -- -- --
fc1/32 1 auto on sfpAbsent -- -- --
fc1/33 1 auto on sfpAbsent -- -- --
fc1/34 1 auto on sfpAbsent -- -- --
fc1/35 1 auto on sfpAbsent -- -- --
fc1/36 1 auto on sfpAbsent -- -- --
fc1/37 1 auto on down swl -- --
fc1/38 1 auto on down swl -- --
fc1/39 1 auto on sfpAbsent -- -- --
fc1/40 1 auto on sfpAbsent -- -- --
fc1/41 1 auto on sfpAbsent -- -- --
fc1/42 1 auto on sfpAbsent -- -- --
fc1/43 1 auto on sfpAbsent -- -- --
fc1/44 1 auto on sfpAbsent -- -- --
fc1/45 1 auto on sfpAbsent -- -- --
fc1/46 1 auto on sfpAbsent -- -- --
fc1/47 1 auto on sfpAbsent -- -- --
fc1/48 1 auto on sfpAbsent -- -- --
Interface Status Speed
(Gbps)
sup-fc0 up 1
Interface Status IP Address Speed MTU
mgmt0 up 10.11.34.199/24 10 Mbps 1500
BCDC91481U45B#
BCDC91481U45B# show lic
license_AMS15390299_15.lic:
SERVER this_host ANY
VENDOR cisco
INCREMENT PORT_ACTIVATION_PKG cisco 1.0 permanent 8 VENDOR_STRING=MDS \
HOSTID=VDH=AMS15390299 \
NOTICE=<LicFileID>20111017131244000</LicFileID><LicLineID>1</LicLineID><PAK>DS-C9148-32P-K
9AMS15390299</PAK> \
SIGN=F040F2546BB6
NOTICE=<LicFileID>20111017131244000</LicFileID><LicLineID>2</LicLineID><PAK>DS-C9148-32P-K
SIGN=257DEB3873DE
BCDC91481U45B#
08-05-2015 10:45 AM
so when you are trying to bring the port up you get that error message ? What if you try "no shut" from the command line ?
