Cisco MDS 9148 FC ports not enabled
michael_cothron
I have reset the 9148 SAN swithc back to factory defaults, when I try to enable the FC ports I get: no Enabled FC ports.
License looks correct, 32 ports enabled
any other ideas?
5 Replies 5
dynamoxxx
Level 5
Level 5
according to your picture the switch is in NPV mode, typically when you reset to factor defaults (write erase and then reload) ..it should be in normal "switched" mode ..not NPV for sure.
@dynamoxxx
You are correct this switch had been set to NPV mode, here is another switch I did the reset on from the start without any changes to NPV, and I have the same problem..It has the same error
port licenses installed ? Can you post output from "sh int br"
@dynamoxxx
BCDC91481U45B# sh int br
Interface  Vsan   Admin  Admin   Status          SFP    Oper  Oper   Port
                  Mode   Trunk                          Mode  Speed  Channel
                         Mode                                 (Gbps)
fc1/1      1      auto   on      down             swl    --           --
fc1/2      1      auto   on      down             swl    --           --
fc1/3      1      auto   on      down             swl    --           --
fc1/4      1      auto   on      down             swl    --           --
fc1/5      1      auto   on      down             swl    --           --
fc1/6      1      auto   on      down             swl    --           --
fc1/7      1      auto   on      down             swl    --           --
fc1/8      1      auto   on      down             swl    --           --
fc1/9      1      auto   on      down             swl    --           --
fc1/10     1      auto   on      down             swl    --           --
fc1/11     1      auto   on      down             swl    --           --
fc1/12     1      auto   on      down             swl    --           --
fc1/13     1      auto   on      down             swl    --           --
fc1/14     1      auto   on      down             swl    --           --
fc1/15     1      auto   on      down             swl    --           --
fc1/16     1      auto   on      down             swl    --           --
fc1/17     1      auto   on      down             swl    --           --
fc1/18     1      auto   on      down             swl    --           --
fc1/19     1      auto   on      down             swl    --           --
fc1/20     1      auto   on      down             swl    --           --
fc1/21     1      auto   on      down             swl    --           --
fc1/22     1      auto   on      down             swl    --           --
fc1/23     1      auto   on      down             swl    --           --
fc1/24     1      auto   on      down             swl    --           --
fc1/25     1      auto   on      down             swl    --           --
fc1/26     1      auto   on      down             swl    --           --
fc1/27     1      auto   on      down             swl    --           --
fc1/28     1      auto   on      down             swl    --           --
fc1/29     1      auto   on      down             swl    --           --
fc1/30     1      auto   on      down             swl    --           --
fc1/31     1      auto   on      sfpAbsent        --     --           --
fc1/32     1      auto   on      sfpAbsent        --     --           --
fc1/33     1      auto   on      sfpAbsent        --     --           --
fc1/34     1      auto   on      sfpAbsent        --     --           --
fc1/35     1      auto   on      sfpAbsent        --     --           --
fc1/36     1      auto   on      sfpAbsent        --     --           --
fc1/37     1      auto   on      down             swl    --           --
fc1/38     1      auto   on      down             swl    --           --
fc1/39     1      auto   on      sfpAbsent        --     --           --
fc1/40     1      auto   on      sfpAbsent        --     --           --
fc1/41     1      auto   on      sfpAbsent        --     --           --
fc1/42     1      auto   on      sfpAbsent        --     --           --
fc1/43     1      auto   on      sfpAbsent        --     --           --
fc1/44     1      auto   on      sfpAbsent        --     --           --
fc1/45     1      auto   on      sfpAbsent        --     --           --
fc1/46     1      auto   on      sfpAbsent        --     --           --
fc1/47     1      auto   on      sfpAbsent        --     --           --
fc1/48     1      auto   on      sfpAbsent        --     --           --
Interface                Status                            Speed
                                                           (Gbps)
sup-fc0                  up                                1
Interface               Status     IP Address         Speed     MTU
mgmt0                    up         10.11.34.199/24    10 Mbps  1500
BCDC91481U45B#
BCDC91481U45B# show lic
license_AMS15390299_15.lic:
SERVER this_host ANY
VENDOR cisco
INCREMENT PORT_ACTIVATION_PKG cisco 1.0 permanent 8 VENDOR_STRING=MDS \
        HOSTID=VDH=AMS15390299 \
        NOTICE=<LicFileID>20111017131244000</LicFileID><LicLineID>1</LicLineID><PAK>DS-C9148-32P-K
9AMS15390299</PAK> \
        SIGN=F040F2546BB6
        NOTICE=<LicFileID>20111017131244000</LicFileID><LicLineID>2</LicLineID><PAK>DS-C9148-32P-K
        SIGN=257DEB3873DE
BCDC91481U45B#
so when you are trying to bring the port up you get that error message ? What if you try "no shut"  from the command line ?
@dynamoxxx
