Cisco Nexus 1010 Not Accepting HyperV Integration Commands
ryan3kip
I have a Cisco Nexus 1010 Virtual Switch Appliance running version 5.2(1)SP1(7.1) which I want to Integrate with Microsoft HyperV. I gone through the setup dialog. However the vsa is not accepting any commands for the HyperV integration:
DC-N1K-VSA-01(config)# nsm
No token match at '^' marker.
please advise whether there is a way I can convert the VSA to accept the HyperV integration commads.
David Silva
Hi Ryan,
The VSA (1010) is essentailly a special hypervisor that can host both VMware and Hyper-V VSMs. You will have to create the Hyper-V VSM in the VSA. Once that VSM is created, you should be to integrate that with SCVMM.
Let me know if you have any questions.
-David
Hi David,
Thank you very much.
Do you have a link any documentation on how to install a VSM on the VSA?
Hi Ryan,
Here is a link that goes over setting up the 1010 and installing the VSM on the VSA.
http://www.cisco.com/c/en/us/td/docs/switches/datacenter/nexus1000/sw/4_0_4_s_p_1_1/software/configuration/guide/n1010_vsvcs_cfg/n1010_vsvcs_cfg_1oview.html
David
