Cisco UCS FI6324 connected to VTL or Tape Library
mpsotomayor
Hi every one.
is its posible to connect directly my tape library quantum and my VTL quantum throught FCP to my FI6324?
if not. which is the best way to doit and who will create de corrects vsan or zoning for this scenario.
thank you
Yes, correct ! Connect each MDS with a UCS FI, building a dual FC fabric ! You will create a VSAN on each fabric (e.g. 10 on fabric A, 11 on fabric B) and then do FC zoning in each VSAN and fabric.
7 Replies 7
Walter Dey
check the proper interop matrix https://ucshcltool.cloudapps.cisco.com/public/, and you will find that
  • 59 : Direct connect of tape libraries is not supported
thanks for the info.
what i should choose in the operatibility matrix (1- Servers 2- Operative System 3- Products).
just for donwload de notes for our client.
regards
Fill out all the information regarding UCS, version, blade, OS, version, then select storage....
see attachment
thank now i got the summary.
in conclution between the FI6324 UCS mini and the tape library i need a MDS switch?
in my desing im using :
*-chassis blade with FI6324
*-4 blades BM200 M4 with VIC1340.
*-2 MDS 9132.
*-conect the MDS 9132 wth SFP 8Gbps FC with Fiber Optic cables LC-LC.
*- connect the Quantum Scalar I3 through the  MDS with the FI6324 UCS Mini with cable LC-LC OM4 and SFP8Gbps FC.
you think that would i have a problem in the installation moments?
Hi Walter
I am trying to P2V my backup server which has a tape library connected to it. Below is my setup
Please refer to my post and advise
https://community.cisco.com/t5/unified-computing-system/fiber-channel-tape-library-connectivity-to-esxi-cisco-ucs-5108/td-p/3677164
Direct connect means bypassing SAN switch?
