Connect to ad MDS 9000 family
lorenzochioffi
Can i connect to mds9000 family with putty an ethernet cable and the default ipv4 (if exists)?
Hi ,
 Yes you can login .
Management Interface
The management interface allows multiple simultaneous Telnet or SNMP sessions. You can remotely configure the device through the management interface (mgmt0), but first you must configure some IP parameters so that the switch is reachable. You can manually configure the management interface from the CLI. You can configure the mgmt 0 interface with either IPv4 address parameters or an IPv6 address.
http://www.cisco.com/c/en/us/td/docs/switches/datacenter/mds9000/sw/6_2/configuration/guides/fundamentals/b_Cisco_MDS_9000_Series_NX-OS_Fundamentals_Configuration_Guide_Release_6_x/b_Cisco_MDS_9000_Series_NX-OS_Fundamentals_Configuration_Guide_Releas...
Sandy
This discussion has been reposted from Cisco User Groups to the Storage Networking community.
