Connecting the nexus 5500 with multiple vsans
frede_frede
it's my first experience in the fibre channel world and i have a few doubts about the best way to connect the nexus 5500 to a EMC storage.
This is my scenario
this is my configuration:
vsan database
vsan 2
vsan 2 interface fc 1/1
vsan 3
vsan 3 interface fc 1/2
interface fc1/1
switchport mode f
no shut
interface fc1/2
switchport mode f
no shut
now I don't know how can I connect the port fc1/3 to the vnx storage, I think I can't make a trunk like ethernet, can anyone help me?
Or i only can do this with zoning
Fred
Vu Phan
Hello Fred,
All interfaces must be in the same vsan for them to see each other
vsan database
vsan 2 interface fc1/1, fc1/2, fc1/3
exit
Then you can zone each separately
example:
zone name host1 vsan 2
member pwwn 11:11:11:11:11:11:11:11    (host1 pwwn)
member pwwn 33:33:33:33:33:33:33:33    (VNX)
zone name host2 vsan 2
member pwwn 22:22:22:22:22:22:22:22    (host2 pwwn)
zoneset name Zoneset1 vsan 2
mem host1
mem host2
zoneset activate name Zoneset1 vsan 2
6 Replies 6
Vu Phan
Hello Fred,
vsan database
exit
example:
mem host1
mem host2
Hi thanks for the help, much appreciated
So I only use VSAN when there are no common interfaces, right?
Only some doubts, in the zoneset if i have to ad a new server I only need to configure the pwwn right? Do you recommend fcalias?
Best regards
Fred
Hello Fred,
If you are configure fcalias, you can use it for zone/zoneset only.  But I would go with Device-alias for more flexibility or wwpn if a small number of ports and if you don't care the other two.
Device alias is not VSAN specific, you're right, Device-alias is a good feature
only one more question, if I want to use Vsans I need another interface in the vnx or another storage, right?
Thanks for the help
Best regards
Fred
Hello Fred,
That is correct, you will need another VNX interface if you want to create another vsan or multiple vsans.
There is another feature IVR (Inter Vsan Routing) to allow the vsans to see each other. But the 5500 is not supported
Thank you for all the help
Best regards
Fred
