create logical disks ucs c220 ?
adewannain
hello,
I have problem with my server Cisco UCS C220 M3S with SD card
I want install windows Server 2012 R2.
so if I use the os install DVD no see my SD card.
If use SCU iso en use menu "OS install" have message :
"Warning : OS installation can not be done as no logical disks found in the system. Please use RAID configuration to create logical Disks." (see Os_install.jpg)
On CIMC my Raid is Healthy, in virtual drive my disk HV is host acceccible.(see virtual_drive_info.jpg and controller_info.jpg)
so I don't understand why don't functionning... HELP ME PLEASE.
Kirk J
Greetings.
I'm not sure if the C220 M3 was tested/certified with the 64GB cards.  The current spec sheet only lists 32GB models.  Do you have access to any of the PIDs available on the specsheet : http://www.cisco.com/c/dam/en/us/products/collateral/servers-unified-computing/ucs-c-series-rack-servers/c220m3-sff-specsheet.pdf
UCS-SD-32G-S 32 GB SD Card for UCS servers
As far as I know, the 64GB models are for the M4 line.
thanks,
Kirk..
