DCNM question
Daniel Chojecki
Hello!
I had to replace one switch in my infrastructure to new one. After that in DCNM i can see the old switch and new but all VSANs are segmented because the old switch is in network map without any connection. Is it possible to remove the old switch from DCNM configuration and how to do it? Or will it be better to remove this Fabric and add it again to DCNM?
Best Regards
Daniel
dynamoxxx
Level 5
Level 5
Remove that fabric in DCNM and re-add it back.
@dynamoxxx
dynamoxxx
Level 5
Level 5
@dynamoxxx
unfortunately i could not purge that switch on network map and i had to remove it and re-add it back ;-)
