Difference between disruptive and non-disruptive MDS9xxx upgrade
b.e.leblanc
Hi All,
I'm curious what the difference between a disruptive and non-disruptive upgrade (for both kickstart and system) on the MDS9xxx series fabric switches?
For example does a non-disruptive mean no reboot/reset is required?
Thanks in advance,
-Brian
Brian
The difference is that FC traffic wil be disrupted or not.
There may well be various module resets/reboots/failovers but FC traffic will not suffer.
As an example, I've just upgraded some 9148's they performed a reboot, causing me to loose my SSH session, but there was no disruption to FC traffic.
Steven
Brian
Steven
Steven, thanks so much as that makes sense.  I just performed a non-disruptive on a lab switch.
Compatibility check is done:
Module  bootable          Impact  Install-type  Reason
     1       yes  non-disruptive         reset Compatibility check is done:
The install-type said reset and I lost my SSH session so I was worried about doing such an upgrade in production because of the reboot.
Kudos!
-Brian
