Error disabled - bit error rate too high on MDS switch
I have been trying to perform an NDMP backup between A HP LTO5 Ultrium Tape Library and Netapp with the MDS switch providing the fabric.
However, everytime I initiate the job, I experience this problem.
Below are some of the outputs on the concerned FC Ports:
MDS-SW01# sh int fc1/27
fc1/27 is down (Error disabled - bit error rate too high)
    Hardware is Fibre Channel, SFP is short wave laser w/o OFC (SN)
    Port WWN is 20:1b:54:7f:ee:e2:8d:00
    Admin port mode is auto, trunk mode is on
    snmp link state traps are enabled
    Port vsan is 2
    Receive data field Size is 2112
    Beacon is turned off
    5 minutes input rate 0 bits/sec, 0 bytes/sec, 0 frames/sec
    5 minutes output rate 0 bits/sec, 0 bytes/sec, 0 frames/sec
      263045 frames input, 12907156 bytes
        0 discards, 0 errors
        0 CRC,  0 unknown class
        0 too long, 0 too short
      4308477 frames output, 8677425352 bytes
        1 discards, 0 errors
      2 input OLS, 2 LRR, 0 NOS, 3 loop inits
      5 output OLS, 2 LRR, 1 NOS, 3 loop inits
    Interface last changed at Mon Oct 13 07:36:46 2014
MDS-SW01# sh int fc1/27 counters
fc1/27
      0 class-2 frames, 0 bytes
      263045 class-3 frames, 12907156 bytes
      0 class-f frames, 0 bytes
      0 discards, 0 errors, 0 CRC
      0 unknown class, 0 too long, 0 too short
      4308477 class-3 frames, 8677425352 bytes
    1 link failures, 1 sync losses, 1 signal losses
     9 BB credit transitions from zero
      32 receive B2B credit remaining
      0 transmit B2B credit remaining
      0 low priority transmit B2B credit remaining
What could be causing the issue and what is the solution?!
Thanks.
hi,
If SFPs have been replaced, it's time for the cables and patch-panels.
15 Replies 15
Walter Dey
Is this the same problem, as discussed under
https://supportforums.cisco.com/discussion/12322531/cisco-mds-switch-port-unavailable ??
and
https://supportforums.cisco.com/discussion/12322021/nexus-5548-lto3-tape-drives-interface-down
Please provide a drawing of the configuration, with
- FC port type, speed, medium (show interface of every FC port, tape as well as Netapp)
- show flogi database
- is there a FC speed mismatch between tape and Netapp ?
Hi wdey,
This is same case as https://supportforums.cisco.com/discussion/12322531/cisco-mds-switch-port-unavailable!
MDS Output
MDS-SW01# sh flo dA
INTERFACE        VSAN    FCID           PORT NAME               NODE NAME
fc1/1            2     0x640000  21:00:00:24:ff:47:86:a8 20:00:00:24:ff:47:86:a8
fc1/2            2     0x641000  50:0a:09:82:9d:ef:09:57 50:0a:09:80:8d:ef:09:57
fc1/3            2     0x641d00  21:00:00:24:ff:47:d2:c9 20:00:00:24:ff:47:d2:c9
fc1/4            2     0x640300  21:00:00:24:ff:48:8d:f9 20:00:00:24:ff:48:8d:f9
fc1/5            2     0x640a00  21:00:00:24:ff:48:8b:1e 20:00:00:24:ff:48:8b:1e
fc1/6            2     0x640800  10:00:00:00:c9:86:ce:31 20:00:00:00:c9:86:ce:31
fc1/7            2     0x640600  10:00:00:00:c9:8f:37:ad 20:00:00:00:c9:8f:37:ad
fc1/8            2     0x642500  21:00:00:24:ff:40:8c:ad 20:00:00:24:ff:40:8c:ad
fc1/9            2     0x640d00  21:00:00:24:ff:48:89:80 20:00:00:24:ff:48:89:80
fc1/10           2     0x641100  10:00:00:00:c9:88:c3:6a 20:00:00:00:c9:88:c3:6a
fc1/11           2     0x640e00  21:00:00:24:ff:48:8d:fc 20:00:00:24:ff:48:8d:fc
fc1/12           2     0x641200  50:0a:09:81:8d:ef:09:57 50:0a:09:80:8d:ef:09:57
fc1/13           2     0x641300  10:00:00:00:c9:8f:32:50 20:00:00:00:c9:8f:32:50
fc1/14           2     0x641400  10:00:00:00:c9:8c:bf:b2 20:00:00:00:c9:8c:bf:b2
fc1/15           2     0x641700  21:00:00:24:ff:47:cf:82 20:00:00:24:ff:47:cf:82
fc1/16           2     0x641e00  50:0a:09:80:01:5e:25:98 50:0a:09:80:01:5e:25:98
fc1/18           2     0x641b00  21:01:00:1b:32:21:e8:99 20:01:00:1b:32:21:e8:99
fc1/19           2     0x641a00  50:01:04:f0:00:cb:ec:81 50:01:04:f0:00:cb:ec:80
fc1/20           2     0x641c00  10:00:00:00:c9:9e:2b:f4 20:00:00:00:c9:9e:2b:f4
fc1/22           2     0x642000  20:1f:00:2a:6a:7c:48:80 20:02:00:2a:6a:7c:48:81
fc1/22           2     0x642001  20:00:00:25:b5:11:1a:00 20:00:00:25:b5:11:00:08
fc1/22           2     0x642002  20:00:00:25:b5:11:1a:02 20:00:00:25:b5:11:00:0a
fc1/22           2     0x642008  20:00:00:25:b5:11:1a:04 20:00:00:25:b5:11:00:0c
fc1/22           2     0x642010  20:00:00:25:b5:11:1a:06 20:00:00:25:b5:11:00:0e
fc1/23           2     0x642300  50:0a:09:81:88:fa:b7:9a 50:0a:09:80:88:fa:b7:9a
fc1/24           2     0x641f00  20:20:00:2a:6a:7c:48:80 20:02:00:2a:6a:7c:48:81
fc1/24           2     0x641f01  20:00:00:25:b5:11:1a:01 20:00:00:25:b5:11:00:09
fc1/24           2     0x641f02  20:00:00:25:b5:11:1a:03 20:00:00:25:b5:11:00:0b
fc1/24           2     0x641f04  20:00:00:25:b5:11:1a:05 20:00:00:25:b5:11:00:0d
fc1/24           2     0x641f08  20:00:00:25:b5:11:1a:07 20:00:00:25:b5:11:00:0f
fc1/27           2     0x641900  50:01:04:f0:00:cb:ec:8e 50:01:04:f0:00:cb:ec:8d
MDS-SW01# sh int fc1/27 (Tape connected here)
fc1/27 is up
    Port mode is F, FCID is 0x641900
    Port vsan is 2
    Speed is 4 Gbps
    Rate mode is dedicated
    Transmit B2B Credit is 8
    Receive B2B Credit is 32
    5 minutes input rate 6896 bits/sec, 862 bytes/sec, 1 frames/sec
    5 minutes output rate 504 bits/sec, 63 bytes/sec, 1 frames/sec
      2057274 frames input, 96810136 bytes
      33868435 frames output, 68232891832 bytes
        37 discards, 0 errors
      6 input OLS, 6 LRR, 0 NOS, 27 loop inits
      12 output OLS, 3 LRR, 3 NOS, 7 loop inits
      8 transmit B2B credit remaining
      8 low priority transmit B2B credit remaining
    Interface last changed at Thu Oct 16 08:00:54 2014\
MDS-SW01# sh int fc1/23 (Netapp connected here)
fc1/23 is up
    Port WWN is 20:17:54:7f:ee:e2:8d:00
    Port mode is F, FCID is 0x642300
    Port vsan is 2
    Speed is 4 Gbps
    Transmit B2B Credit is 3
    5 minutes input rate 814872 bits/sec, 101859 bytes/sec, 337 frames/sec
    5 minutes output rate 10494656 bits/sec, 1311832 bytes/sec, 796 frames/sec
      13668826268 frames input, 18767974115904 bytes
      24873403718 frames output, 46226980943856 bytes
        25 discards, 0 errors
      2 input OLS, 0 LRR, 0 NOS, 7 loop inits
      7 output OLS, 7 LRR, 6 NOS, 7 loop inits
      3 transmit B2B credit remaining
      3 low priority transmit B2B credit remaining
    Interface last changed at Thu Oct 16 06:54:13 2014
Tape Data:
The info for the tape Library has been a challenge to retrieve, however, Documentation states that the FC Port can support upto 4GB. On the SL Console, it is showing that it is in Auto! With N_mode.
Netapp Extract.
        slot 0: Fibre Channel Target Host Adapter 0b
                (QLogic 2432 (2462) rev. 2, <ONLINE>)
                Firmware rev:      5.5.2
                Host Port Addr:    642300
                Connection:        PTP, Fabric
                Switch Port:       ---------
                SFP Vendor Name:   AVAGO
                SFP Vendor P/N:    AFBR-57R6APZ-NA1
                SFP Vendor Rev:
                SFP Serial No.:    AVAGCN09074826DP
                SFP Connector:     LC
                SFP Capabilities:  1, 2, 4 Gbit/Sec
                        I/O base 0x00009800, size 0x100
                        memory mapped I/O base 0xfe0fc000, size 0x4000
#fcp show adapter -v
Slot:                    0b
Description:             Fibre Channel Target Adapter 0b (QLogic 2432 (2462) rev. 2)
Status:                  ONLINE
Host Port Address:       0x642300
Firmware Rev:            5.5.2
FC Packet Size:          2048
Data Link Rate:          4 GBit
Adapter Type:            Local
Fabric Established:      Yes
Connection Established:  PTP
Mediatype:               auto
Partner Adapter:         None
Standby:                 No
Target Port ID:          0x1
Switch Port:             ----------
We set the speed on the MDS switch to 4GB on the port where the tape library is connected, hoping to address the speed mismatch, but still had same issue!
Here are some of the logs off the MDS switch!
2014 Oct  1 01:53:12 --MDS-SW01 %PORT-2-IF_DOWN_LINK_FAILURE: %$VSAN 2%$ Interface fc1/20 is down (Link failure)
2014 Oct  1 01:55:53 --MDS-SW01 %PORT-2-IF_DOWN_LINK_FAILURE: %$VSAN 2%$ Interface fc1/20 is down (Link failure)
2014 Oct  1 01:55:53 --MDS-SW01 %PORT-5-IF_UP: %$VSAN 2%$ Interface fc1/20 is up in mode F
2014 Oct  1 02:01:41 --MDS-SW01 %PORT-4-IF_SFP_WARNING: Interface fc1/20, Low Rx Power Warning
2014 Oct  1 02:01:41 --MDS-SW01 %PORT-3-IF_SFP_ALARM: Interface fc1/20, Low Rx Power Alarm
2014 Oct  1 02:11:42 --MDS-SW01 %PORT-4-IF_SFP_WARNING: Interface fc1/20, Low Rx Power Warning cleared
2014 Oct  1 02:11:42 --MDS-SW01 %PORT-3-IF_SFP_ALARM: Interface fc1/20, Low Rx Power Alarm cleared
2014 Oct  1 03:41:42 --MDS-SW01 %PORT-4-IF_SFP_WARNING: Interface fc1/12, Low Rx Power Warning
2014 Oct  1 03:41:42 --MDS-SW01 %PORT-3-IF_SFP_ALARM: Interface fc1/12, Low Rx Power Alarm
2014 Oct  1 20:51:42 --MDS-SW01 %PORT-4-IF_SFP_WARNING: Interface fc1/12, Low Rx Power Warning
2014 Oct  1 20:51:42 --MDS-SW01 %PORT-3-IF_SFP_ALARM: Interface fc1/12, Low Rx Power Alarm cleared
2014 Oct  1 21:01:42 --MDS-SW01 %PORT-4-IF_SFP_WARNING: Interface fc1/12, Low Rx Power Warning
2014 Oct  1 21:01:42 --MDS-SW01 %PORT-3-IF_SFP_ALARM: Interface fc1/12, Low Rx Power Alarm
2014 Oct  2 08:16:40 --MDS-SW01 %PORT-2-IF_DOWN_LINK_FAILURE: %$VSAN 2%$ Interface fc1/18 is down (Link failure)
2014 Oct  2 08:18:47 --MDS-SW01 %PORT-2-IF_DOWN_LINK_FAILURE: %$VSAN 2%$ Interface fc1/18 is down (Link failure)
2014 Oct  2 08:18:47 --MDS-SW01 %PORT-5-IF_UP: %$VSAN 2%$ Interface fc1/18 is up in mode F
2014 Oct  2 08:21:41 --MDS-SW01 %PORT-4-IF_SFP_WARNING: Interface fc1/18, Low Rx Power Warning
2014 Oct  2 08:21:41 --MDS-SW01 %PORT-3-IF_SFP_ALARM: Interface fc1/18, Low Rx Power Alarm
2014 Oct  2 08:31:42 --MDS-SW01 %PORT-4-IF_SFP_WARNING: Interface fc1/18, Low Rx Power Warning cleared
2014 Oct  2 08:31:42 --MDS-SW01 %PORT-3-IF_SFP_ALARM: Interface fc1/18, Low Rx Power Alarm cleared
2014 Oct  3 08:39:27 --MDS-SW01 %PORT-2-IF_DOWN_LINK_FAILURE: %$VSAN 2%$ Interface fc1/10 is down (Link failure)
2014 Oct  3 08:41:59 --MDS-SW01 %PORT-2-IF_DOWN_LINK_FAILURE: %$VSAN 2%$ Interface fc1/10 is down (Link failure)
2014 Oct  3 08:41:59 --MDS-SW01 %PORT-5-IF_UP: %$VSAN 2%$ Interface fc1/10 is up in mode F
2014 Oct  3 08:51:42 --MDS-SW01 %PORT-4-IF_SFP_WARNING: Interface fc1/10, Low Rx Power Warning
2014 Oct  3 08:51:42 --MDS-SW01 %PORT-3-IF_SFP_ALARM: Interface fc1/10, Low Rx Power Alarm
2014 Oct  3 09:01:42 --MDS-SW01 %PORT-4-IF_SFP_WARNING: Interface fc1/10, Low Rx Power Warning cleared
2014 Oct  3 09:01:42 --MDS-SW01 %PORT-3-IF_SFP_ALARM: Interface fc1/10, Low Rx Power Alarm cleared
2014 Oct  3 19:21:41 --MDS-SW01 %PORT-4-IF_SFP_WARNING: Interface fc1/12, Low Rx Power Warning
2014 Oct  3 19:21:41 --MDS-SW01 %PORT-3-IF_SFP_ALARM: Interface fc1/12, Low Rx Power Alarm cleared
2014 Oct  3 19:31:42 --MDS-SW01 %PORT-4-IF_SFP_WARNING: Interface fc1/12, Low Rx Power Warning
2014 Oct  3 19:31:42 --MDS-SW01 %PORT-3-IF_SFP_ALARM: Interface fc1/12, Low Rx Power Alarm
2014 Oct  3 19:51:42 --MDS-SW01 %PORT-4-IF_SFP_WARNING: Interface fc1/12, Low Rx Power Warning
2014 Oct  3 19:51:42 --MDS-SW01 %PORT-3-IF_SFP_ALARM: Interface fc1/12, Low Rx Power Alarm cleared
2014 Oct  3 20:01:42 --MDS-SW01 %PORT-4-IF_SFP_WARNING: Interface fc1/12, Low Rx Power Warning
2014 Oct  3 20:01:42 --MDS-SW01 %PORT-3-IF_SFP_ALARM: Interface fc1/12, Low Rx Power Alarm
2014 Oct  3 20:11:41 --MDS-SW01 %PORT-4-IF_SFP_WARNING: Interface fc1/12, Low Rx Power Warning
2014 Oct  3 20:11:41 --MDS-SW01 %PORT-3-IF_SFP_ALARM: Interface fc1/12, Low Rx Power Alarm cleared
2014 Oct  3 20:21:42 --MDS-SW01 %PORT-4-IF_SFP_WARNING: Interface fc1/12, Low Rx Power Warning
2014 Oct  3 20:21:42 --MDS-SW01 %PORT-3-IF_SFP_ALARM: Interface fc1/12, Low Rx Power Alarm
2014 Oct  3 21:51:42 --MDS-SW01 %PORT-4-IF_SFP_WARNING: Interface fc1/12, Low Rx Power Warning
2014 Oct  3 21:51:42 --MDS-SW01 %PORT-3-IF_SFP_ALARM: Interface fc1/12, Low Rx Power Alarm cleared
2014 Oct  3 22:01:41 --MDS-SW01 %PORT-4-IF_SFP_WARNING: Interface fc1/12, Low Rx Power Warning
2014 Oct  3 22:01:41 --MDS-SW01 %PORT-3-IF_SFP_ALARM: Interface fc1/12, Low Rx Power Alarm
2014 Oct  6 01:31:20 --MDS-SW01 %PORT-2-IF_DOWN_LINK_FAILURE: %$VSAN 2%$ Interface fc1/18 is down (Link failure)
2014 Oct  6 01:33:27 --MDS-SW01 %PORT-2-IF_DOWN_LINK_FAILURE: %$VSAN 2%$ Interface fc1/18 is down (Link failure)
2014 Oct  6 01:33:27 --MDS-SW01 %PORT-5-IF_UP: %$VSAN 2%$ Interface fc1/18 is up in mode F
2014 Oct  6 01:41:42 --MDS-SW01 %PORT-4-IF_SFP_WARNING: Interface fc1/18, Low Rx Power Warning
2014 Oct  6 01:41:42 --MDS-SW01 %PORT-3-IF_SFP_ALARM: Interface fc1/18, Low Rx Power Alarm
2014 Oct  6 01:51:42 --MDS-SW01 %PORT-4-IF_SFP_WARNING: Interface fc1/18, Low Rx Power Warning cleared
2014 Oct  6 01:51:42 --MDS-SW01 %PORT-3-IF_SFP_ALARM: Interface fc1/18, Low Rx Power Alarm cleared
2014 Oct  7 02:02:27 --MDS-SW01 %PORT-2-IF_DOWN_LINK_FAILURE: %$VSAN 2%$ Interface fc1/10 is down (Link failure)
2014 Oct  7 02:04:57 --MDS-SW01 %PORT-2-IF_DOWN_LINK_FAILURE: %$VSAN 2%$ Interface fc1/10 is down (Link failure)
2014 Oct  7 02:04:57 --MDS-SW01 %PORT-5-IF_UP: %$VSAN 2%$ Interface fc1/10 is up in mode F
2014 Oct  7 02:11:42 --MDS-SW01 %PORT-4-IF_SFP_WARNING: Interface fc1/10, Low Rx Power Warning
2014 Oct  7 02:11:42 --MDS-SW01 %PORT-3-IF_SFP_ALARM: Interface fc1/10, Low Rx Power Alarm
2014 Oct  7 02:21:41 --MDS-SW01 %PORT-4-IF_SFP_WARNING: Interface fc1/10, Low Rx Power Warning cleared
2014 Oct  7 02:21:41 --MDS-SW01 %PORT-3-IF_SFP_ALARM: Interface fc1/10, Low Rx Power Alarm cleared
2014 Oct  8 10:26:38 --MDS-SW01 %MODULE-4-MOD_WARNING: Module 1 (serial: JAF1721BBMA) reported warning on ports 1/25-1/25 (Fibre Channel) due to MAC Bit error exceeded threshold in device 127 (de
vice error 0xc7f00503)
2014 Oct  8 10:26:38 --MDS-SW01 %PORT-5-IF_DOWN_BIT_ERR_RT_THRES_EXCEEDED: %$VSAN 2%$ Interface fc1/25 is down (Error disabled - bit error rate too high)
2014 Oct  9 00:52:52 --MDS-SW01 %PORT-2-IF_DOWN_LINK_FAILURE: %$VSAN 2%$ Interface fc1/26 is down (Link failure)
2014 Oct  9 00:52:54 --MDS-SW01 %PORT-2-IF_DOWN_LINK_FAILURE: %$VSAN 2%$ Interface fc1/26 is down (Link failure)
2014 Oct  9 00:52:54 --MDS-SW01 %PORT-5-IF_UP: %$VSAN 2%$ Interface fc1/26 is up in mode F
2014 Oct  9 00:53:02 --MDS-SW01 %PORT-2-IF_DOWN_LINK_FAILURE: %$VSAN 2%$ Interface fc1/19 is down (Link failure)
2014 Oct  9 00:53:06 --MDS-SW01 %PORT-2-IF_DOWN_LINK_FAILURE: %$VSAN 2%$ Interface fc1/19 is down (Link failure)
2014 Oct  9 00:53:06 --MDS-SW01 %PORT-5-IF_UP: %$VSAN 2%$ Interface fc1/19 is up in mode F
2014 Oct  9 00:53:12 --MDS-SW01 %PORT-2-IF_DOWN_LINK_FAILURE: %$VSAN 2%$ Interface fc1/19 is down (Link failure)
2014 Oct  9 00:53:16 --MDS-SW01 %PORT-2-IF_DOWN_LINK_FAILURE: %$VSAN 2%$ Interface fc1/19 is down (Link failure)
2014 Oct  9 00:53:16 --MDS-SW01 %PORT-5-IF_UP: %$VSAN 2%$ Interface fc1/19 is up in mode F
2014 Oct  9 00:54:01 --MDS-SW01 %PORT-2-IF_DOWN_LINK_FAILURE: %$VSAN 2%$ Interface fc1/26 is down (Link failure)
2014 Oct  9 00:54:09 --MDS-SW01 %PORT-2-IF_DOWN_LINK_FAILURE: %$VSAN 2%$ Interface fc1/26 is down (Link failure)
2014 Oct  9 00:54:09 --MDS-SW01 %PORT-5-IF_UP: %$VSAN 2%$ Interface fc1/26 is up in mode F
2014 Oct  9 01:01:42 --MDS-SW01 %PORT-4-IF_SFP_WARNING: Interface fc1/19, Low Rx Power Warning
2014 Oct  9 01:01:42 --MDS-SW01 %PORT-3-IF_SFP_ALARM: Interface fc1/19, Low Rx Power Alarm
2014 Oct  9 01:11:37 --MDS-SW01 %PORT-2-IF_DOWN_LINK_FAILURE: %$VSAN 2%$ Interface fc1/10 is down (Link failure)
2014 Oct  9 01:11:42 --MDS-SW01 %PORT-2-IF_DOWN_LINK_FAILURE: %$VSAN 2%$ Interface fc1/10 is down (Link failure)
2014 Oct  9 01:11:42 --MDS-SW01 %PORT-4-IF_SFP_WARNING: Interface fc1/19, Low Rx Power Warning cleared
2014 Oct  9 01:11:42 --MDS-SW01 %PORT-3-IF_SFP_ALARM: Interface fc1/19, Low Rx Power Alarm cleared
2014 Oct  9 01:14:08 --MDS-SW01 %PORT-5-IF_UP: %$VSAN 2%$ Interface fc1/10 is up in mode F
2014 Oct  9 01:14:36 --MDS-SW01 %PORT-5-IF_DOWN_BIT_ERR_RT_THRES_EXCEEDED: %$VSAN 2%$ Interface fc1/26 is down (Error disabled - bit error rate too high)
2014 Oct  9 01:14:36 --MDS-SW01 %MODULE-4-MOD_WARNING: Module 1 (serial: JAF1721BBMA) reported warning on ports 1/26-1/26 (Fibre Channel) due to MAC Bit error exceeded threshold in device 127 (de
2014 Oct  9 01:21:42 --MDS-SW01 %PORT-4-IF_SFP_WARNING: Interface fc1/10, Low Rx Power Warning
2014 Oct  9 01:21:42 --MDS-SW01 %PORT-3-IF_SFP_ALARM: Interface fc1/10, Low Rx Power Alarm
2014 Oct  9 01:31:43 --MDS-SW01 %PORT-4-IF_SFP_WARNING: Interface fc1/10, Low Rx Power Warning cleared
2014 Oct  9 01:31:43 --MDS-SW01 %PORT-3-IF_SFP_ALARM: Interface fc1/10, Low Rx Power Alarm cleared
2014 Oct  9 01:32:24 --MDS-SW01 %PORT-2-IF_DOWN_LINK_FAILURE: %$VSAN 2%$ Interface fc1/19 is down (Link failure)
2014 Oct  9 01:35:50 --MDS-SW01 %PORT-2-IF_DOWN_LINK_FAILURE: %$VSAN 2%$ Interface fc1/19 is down (Link failure)
2014 Oct  9 01:35:50 --MDS-SW01 %PORT-5-IF_UP: %$VSAN 2%$ Interface fc1/19 is up in mode F
2014 Oct  9 05:17:26 --MDS-SW01 %PORT-2-IF_DOWN_LINK_FAILURE: %$VSAN 2%$ Interface fc1/19 is down (Link failure)
2014 Oct  9 05:17:30 --MDS-SW01 %PORT-2-IF_DOWN_LINK_FAILURE: %$VSAN 2%$ Interface fc1/19 is down (Link failure)
2014 Oct  9 05:17:30 --MDS-SW01 %PORT-5-IF_UP: %$VSAN 2%$ Interface fc1/19 is up in mode F
2014 Oct  9 05:17:34 --MDS-SW01 %PORT-2-IF_DOWN_LINK_FAILURE: %$VSAN 2%$ Interface fc1/19 is down (Link failure)
2014 Oct  9 05:17:38 --MDS-SW01 %PORT-2-IF_DOWN_LINK_FAILURE: %$VSAN 2%$ Interface fc1/19 is down (Link failure)
2014 Oct  9 05:17:38 --MDS-SW01 %PORT-5-IF_UP: %$VSAN 2%$ Interface fc1/19 is up in mode F
2014 Oct  9 05:18:17 --MDS-SW01 %PORT-2-IF_DOWN_LINK_FAILURE: %$VSAN 2%$ Interface fc1/19 is down (Link failure)
2014 Oct  9 05:21:51 --MDS-SW01 %PORT-2-IF_DOWN_LINK_FAILURE: %$VSAN 2%$ Interface fc1/19 is down (Link failure)
2014 Oct  9 05:21:51 --MDS-SW01 %PORT-5-IF_UP: %$VSAN 2%$ Interface fc1/19 is up in mode F
2014 Oct  9 05:25:56 --MDS-SW01 %PORT-2-IF_DOWN_LINK_FAILURE: %$VSAN 2%$ Interface fc1/19 is down (Link failure)
2014 Oct  9 05:26:00 --MDS-SW01 %PORT-2-IF_DOWN_LINK_FAILURE: %$VSAN 2%$ Interface fc1/19 is down (Link failure)
2014 Oct  9 05:26:00 --MDS-SW01 %PORT-5-IF_UP: %$VSAN 2%$ Interface fc1/19 is up in mode F
2014 Oct  9 05:26:37 --MDS-SW01 %PORT-2-IF_DOWN_LINK_FAILURE: %$VSAN 2%$ Interface fc1/19 is down (Link failure)
2014 Oct  9 05:26:44 --MDS-SW01 %PORT-2-IF_DOWN_LINK_FAILURE: %$VSAN 2%$ Interface fc1/19 is down (Link failure)
2014 Oct  9 05:26:44 --MDS-SW01 %PORT-5-IF_UP: %$VSAN 2%$ Interface fc1/19 is up in mode F
2014 Oct  9 05:29:03 --MDS-SW01 %PORT-5-IF_DOWN_NONE: %$VSAN 4094%$ Interface fc1/25 is down (None)
2014 Oct  9 05:29:09 --MDS-SW01 %PORT-5-IF_UP: %$VSAN 2%$ Interface fc1/27 is up in mode F
2014 Oct  9 05:29:58 --MDS-SW01 %PORT-5-IF_DOWN_NONE: %$VSAN 4094%$ Interface fc1/26 is down (None)
2014 Oct  9 05:30:05 --MDS-SW01 %PORT-5-IF_UP: %$VSAN 2%$ Interface fc1/28 is up in mode F
2014 Oct  9 05:31:43 --MDS-SW01 %PORT-4-IF_SFP_WARNING: Interface fc1/19, Low Rx Power Warning
2014 Oct  9 05:31:43 --MDS-SW01 %PORT-3-IF_SFP_ALARM: Interface fc1/19, Low Rx Power Alarm
2014 Oct  9 05:41:43 --MDS-SW01 %PORT-4-IF_SFP_WARNING: Interface fc1/19, Low Rx Power Warning cleared
2014 Oct  9 05:41:43 --MDS-SW01 %PORT-3-IF_SFP_ALARM: Interface fc1/19, Low Rx Power Alarm cleared
2014 Oct  9 05:57:57 --MDS-SW01 %PORT-2-IF_DOWN_LINK_FAILURE: %$VSAN 2%$ Interface fc1/18 is down (Link failure)
2014 Oct  9 06:00:04 --MDS-SW01 %PORT-2-IF_DOWN_LINK_FAILURE: %$VSAN 2%$ Interface fc1/18 is down (Link failure)
2014 Oct  9 06:00:04 --MDS-SW01 %PORT-5-IF_UP: %$VSAN 2%$ Interface fc1/18 is up in mode F
2014 Oct  9 06:01:43 --MDS-SW01 %PORT-4-IF_SFP_WARNING: Interface fc1/18, Low Rx Power Warning
2014 Oct  9 06:01:43 --MDS-SW01 %PORT-3-IF_SFP_ALARM: Interface fc1/18, Low Rx Power Alarm
2014 Oct  9 06:11:43 --MDS-SW01 %PORT-4-IF_SFP_WARNING: Interface fc1/18, Low Rx Power Warning cleared
2014 Oct  9 06:11:43 --MDS-SW01 %PORT-3-IF_SFP_ALARM: Interface fc1/18, Low Rx Power Alarm cleared
2014 Oct  9 06:18:22 --MDS-SW01 %PORT-2-IF_DOWN_LINK_FAILURE: %$VSAN 2%$ Interface fc1/19 is down (Link failure)
2014 Oct  9 06:18:32 --MDS-SW01 %PORT-2-IF_DOWN_LINK_FAILURE: %$VSAN 2%$ Interface fc1/19 is down (Link failure)
2014 Oct  9 06:18:32 --MDS-SW01 %PORT-5-IF_UP: %$VSAN 2%$ Interface fc1/19 is up in mode F
2014 Oct  9 06:18:39 --MDS-SW01 %PORT-2-IF_DOWN_LINK_FAILURE: %$VSAN 2%$ Interface fc1/19 is down (Link failure)
2014 Oct  9 06:18:49 --MDS-SW01 %PORT-2-IF_DOWN_LINK_FAILURE: %$VSAN 2%$ Interface fc1/19 is down (Link failure)
2014 Oct  9 06:18:49 --MDS-SW01 %PORT-5-IF_UP: %$VSAN 2%$ Interface fc1/19 is up in mode F
2014 Oct  9 06:20:46 --MDS-SW01 %PORT-2-IF_DOWN_LINK_FAILURE: %$VSAN 2%$ Interface fc1/19 is down (Link failure)
2014 Oct  9 06:20:46 --MDS-SW01 %PORT-2-IF_DOWN_LINK_FAILURE: %$VSAN 2%$ Interface fc1/28 is down (Link failure)
2014 Oct  9 06:20:46 --MDS-SW01 %PORT-2-IF_DOWN_LINK_FAILURE: %$VSAN 2%$ Interface fc1/27 is down (Link failure)
2014 Oct  9 06:22:09 --MDS-SW01 %PORT-5-IF_UP: %$VSAN 2%$ Interface fc1/27 is up in mode F
2014 Oct  9 06:22:11 --MDS-SW01 %PORT-5-IF_UP: %$VSAN 2%$ Interface fc1/28 is up in mode F
2014 Oct  9 06:24:06 --MDS-SW01 %PORT-5-IF_UP: %$VSAN 2%$ Interface fc1/19 is up in mode F
2014 Oct  9 06:31:43 --MDS-SW01 %PORT-4-IF_SFP_WARNING: Interface fc1/19, Low Rx Power Warning
2014 Oct  9 06:31:43 --MDS-SW01 %PORT-3-IF_SFP_ALARM: Interface fc1/19, Low Rx Power Alarm
2014 Oct  9 06:41:42 --MDS-SW01 %PORT-4-IF_SFP_WARNING: Interface fc1/19, Low Rx Power Warning cleared
2014 Oct  9 06:41:42 --MDS-SW01 %PORT-3-IF_SFP_ALARM: Interface fc1/19, Low Rx Power Alarm cleared
2014 Oct  9 07:06:44 --MDS-SW01 %MODULE-4-MOD_WARNING: Module 1 (serial: JAF1721BBMA) reported warning on ports 1/27-1/27 (Fibre Channel) due to MAC Bit error exceeded threshold in device 127 (de
2014 Oct  9 07:06:44 --MDS-SW01 %PORT-5-IF_DOWN_BIT_ERR_RT_THRES_EXCEEDED: %$VSAN 2%$ Interface fc1/27 is down (Error disabled - bit error rate too high)
2014 Oct  9 07:36:52 --MDS-SW01 %PORT-5-IF_DOWN_BIT_ERR_RT_THRES_EXCEEDED: %$VSAN 2%$ Interface fc1/28 is down (Error disabled - bit error rate too high)
2014 Oct  9 07:36:52 --MDS-SW01 %MODULE-4-MOD_WARNING: Module 1 (serial: JAF1721BBMA) reported warning on ports 1/28-1/28 (Fibre Channel) due to MAC Bit error exceeded threshold in device 127 (de
2014 Oct 10 04:34:16 --MDS-SW01 %PORT-5-IF_DOWN_ADMIN_DOWN: %$VSAN 2%$ Interface fc1/27 is down (Administratively down)
2014 Oct 10 04:34:20 --MDS-SW01 %PORT-5-IF_DOWN_BIT_ERR_RT_THRES_EXCEEDED: %$VSAN 2%$ Interface fc1/27 is down (Error disabled - bit error rate too high)
2014 Oct 10 04:34:20 --MDS-SW01 %PORT-5-IF_UP: %$VSAN 2%$ Interface fc1/27 is up in mode F
2014 Oct 10 04:34:29 --MDS-SW01 %PORT-5-IF_DOWN_ADMIN_DOWN: %$VSAN 2%$ Interface fc1/28 is down (Administratively down)
2014 Oct 10 04:34:32 --MDS-SW01 %PORT-5-IF_DOWN_BIT_ERR_RT_THRES_EXCEEDED: %$VSAN 2%$ Interface fc1/28 is down (Error disabled - bit error rate too high)
2014 Oct 10 04:34:32 --MDS-SW01 %PORT-5-IF_UP: %$VSAN 2%$ Interface fc1/28 is up in mode F
2014 Oct 10 05:41:08 --MDS-SW01 %PORT-2-IF_DOWN_LINK_FAILURE: %$VSAN 2%$ Interface fc1/18 is down (Link failure)
2014 Oct 10 05:43:15 --MDS-SW01 %PORT-2-IF_DOWN_LINK_FAILURE: %$VSAN 2%$ Interface fc1/18 is down (Link failure)
2014 Oct 10 05:43:15 --MDS-SW01 %PORT-5-IF_UP: %$VSAN 2%$ Interface fc1/18 is up in mode F
2014 Oct 10 05:51:43 --MDS-SW01 %PORT-4-IF_SFP_WARNING: Interface fc1/18, Low Rx Power Warning
2014 Oct 10 05:51:43 --MDS-SW01 %PORT-3-IF_SFP_ALARM: Interface fc1/18, Low Rx Power Alarm
2014 Oct 10 06:01:43 --MDS-SW01 %PORT-4-IF_SFP_WARNING: Interface fc1/18, Low Rx Power Warning cleared
2014 Oct 10 06:01:43 --MDS-SW01 %PORT-3-IF_SFP_ALARM: Interface fc1/18, Low Rx Power Alarm cleared
2014 Oct 12 22:11:43 --MDS-SW01 %PORT-4-IF_SFP_WARNING: Interface fc1/12, Low Rx Power Warning
2014 Oct 12 22:11:43 --MDS-SW01 %PORT-3-IF_SFP_ALARM: Interface fc1/12, Low Rx Power Alarm cleared
2014 Oct 12 22:21:43 --MDS-SW01 %PORT-4-IF_SFP_WARNING: Interface fc1/12, Low Rx Power Warning
2014 Oct 12 22:21:43 --MDS-SW01 %PORT-3-IF_SFP_ALARM: Interface fc1/12, Low Rx Power Alarm
2014 Oct 12 22:31:42 --MDS-SW01 %PORT-4-IF_SFP_WARNING: Interface fc1/12, Low Rx Power Warning
2014 Oct 12 22:31:42 --MDS-SW01 %PORT-3-IF_SFP_ALARM: Interface fc1/12, Low Rx Power Alarm cleared
2014 Oct 12 22:41:43 --MDS-SW01 %PORT-4-IF_SFP_WARNING: Interface fc1/12, Low Rx Power Warning
2014 Oct 12 22:41:43 --MDS-SW01 %PORT-3-IF_SFP_ALARM: Interface fc1/12, Low Rx Power Alarm
2014 Oct 13 06:02:24 --MDS-SW01 %PORT-2-IF_DOWN_LINK_FAILURE: %$VSAN 2%$ Interface fc1/18 is down (Link failure)
2014 Oct 13 06:04:32 --MDS-SW01 %PORT-2-IF_DOWN_LINK_FAILURE: %$VSAN 2%$ Interface fc1/18 is down (Link failure)
2014 Oct 13 06:04:32 --MDS-SW01 %PORT-5-IF_UP: %$VSAN 2%$ Interface fc1/18 is up in mode F
2014 Oct 13 06:11:21 --MDS-SW01 %PORT-2-IF_DOWN_LINK_FAILURE: %$VSAN 2%$ Interface fc1/18 is down (Link failure)
2014 Oct 13 06:18:17 --MDS-SW01 %PORT-2-IF_DOWN_LINK_FAILURE: %$VSAN 2%$ Interface fc1/18 is down (Link failure)
2014 Oct 13 06:18:17 --MDS-SW01 %PORT-5-IF_UP: %$VSAN 2%$ Interface fc1/18 is up in mode F
2014 Oct 13 06:21:42 --MDS-SW01 %PORT-4-IF_SFP_WARNING: Interface fc1/18, Low Rx Power Warning
2014 Oct 13 06:21:42 --MDS-SW01 %PORT-3-IF_SFP_ALARM: Interface fc1/18, Low Rx Power Alarm
2014 Oct 13 06:28:25 --MDS-SW01 %MODULE-4-MOD_WARNING: Module 1 (serial: JAF1721BBMA) reported warning on ports 1/28-1/28 (Fibre Channel) due to MAC Bit error exceeded threshold in device 127 (de
2014 Oct 13 06:28:26 --MDS-SW01 %PORT-5-IF_DOWN_BIT_ERR_RT_THRES_EXCEEDED: %$VSAN 2%$ Interface fc1/28 is down (Error disabled - bit error rate too high)
2014 Oct 13 06:31:43 --MDS-SW01 %PORT-4-IF_SFP_WARNING: Interface fc1/18, Low Rx Power Warning cleared
2014 Oct 13 06:31:43 --MDS-SW01 %PORT-3-IF_SFP_ALARM: Interface fc1/18, Low Rx Power Alarm cleared
2014 Oct 13 06:35:18 --MDS-SW01 %PORT-2-IF_DOWN_LINK_FAILURE: %$VSAN 2%$ Interface fc1/18 is down (Link failure)
2014 Oct 13 06:38:10 --MDS-SW01 %PORT-2-IF_DOWN_LINK_FAILURE: %$VSAN 2%$ Interface fc1/18 is down (Link failure)
2014 Oct 13 06:38:10 --MDS-SW01 %PORT-5-IF_UP: %$VSAN 2%$ Interface fc1/18 is up in mode F
2014 Oct 13 06:41:43 --MDS-SW01 %PORT-4-IF_SFP_WARNING: Interface fc1/18, Low Rx Power Warning
2014 Oct 13 06:41:43 --MDS-SW01 %PORT-3-IF_SFP_ALARM: Interface fc1/18, Low Rx Power Alarm
2014 Oct 13 06:42:35 --MDS-SW01 %PORT-5-IF_DOWN_ADMIN_DOWN: %$VSAN 2%$ Interface fc1/28 is down (Administratively down)
2014 Oct 13 06:42:38 --MDS-SW01 %PORT-5-IF_DOWN_BIT_ERR_RT_THRES_EXCEEDED: %$VSAN 2%$ Interface fc1/28 is down (Error disabled - bit error rate too high)
2014 Oct 13 06:42:39 --MDS-SW01 %PORT-5-IF_UP: %$VSAN 2%$ Interface fc1/28 is up in mode F
2014 Oct 13 06:51:42 --MDS-SW01 %PORT-4-IF_SFP_WARNING: Interface fc1/18, Low Rx Power Warning cleared
2014 Oct 13 06:51:42 --MDS-SW01 %PORT-3-IF_SFP_ALARM: Interface fc1/18, Low Rx Power Alarm cleared
2014 Oct 13 07:36:46 --MDS-SW01 %PORT-5-IF_DOWN_BIT_ERR_RT_THRES_EXCEEDED: %$VSAN 2%$ Interface fc1/27 is down (Error disabled - bit error rate too high)
2014 Oct 13 07:36:46 --MDS-SW01 %MODULE-4-MOD_WARNING: Module 1 (serial: JAF1721BBMA) reported warning on ports 1/27-1/27 (Fibre Channel) due to MAC Bit error exceeded threshold in device 127 (de
2014 Oct 13 08:02:41 --MDS-SW01 %PORT-5-IF_DOWN_BIT_ERR_RT_THRES_EXCEEDED: %$VSAN 2%$ Interface fc1/28 is down (Error disabled - bit error rate too high)
2014 Oct 13 08:02:41 --MDS-SW01 %MODULE-4-MOD_WARNING: Module 1 (serial: JAF1721BBMA) reported warning on ports 1/28-1/28 (Fibre Channel) due to MAC Bit error exceeded threshold in device 127 (de
2014 Oct 14 02:16:18 --MDS-SW01 %PORT-2-IF_DOWN_LINK_FAILURE: %$VSAN 2%$ Interface fc1/19 is down (Link failure)
2014 Oct 14 02:19:44 --MDS-SW01 %PORT-2-IF_DOWN_LINK_FAILURE: %$VSAN 2%$ Interface fc1/19 is down (Link failure)
2014 Oct 14 02:19:44 --MDS-SW01 %PORT-5-IF_UP: %$VSAN 2%$ Interface fc1/19 is up in mode F
2014 Oct 14 03:03:22 --MDS-SW01 %PORT-5-IF_DOWN_ADMIN_DOWN: %$VSAN 2%$ Interface fc1/27 is down (Administratively down)
2014 Oct 14 03:03:27 --MDS-SW01 %PORT-5-IF_DOWN_BIT_ERR_RT_THRES_EXCEEDED: %$VSAN 2%$ Interface fc1/27 is down (Error disabled - bit error rate too high)
2014 Oct 14 03:03:27 --MDS-SW01 %PORT-5-IF_UP: %$VSAN 2%$ Interface fc1/27 is up in mode F
2014 Oct 14 03:03:35 --MDS-SW01 %PORT-5-IF_DOWN_ADMIN_DOWN: %$VSAN 2%$ Interface fc1/28 is down (Administratively down)
2014 Oct 14 03:03:37 --MDS-SW01 %PORT-5-IF_DOWN_BIT_ERR_RT_THRES_EXCEEDED: %$VSAN 2%$ Interface fc1/28 is down (Error disabled - bit error rate too high)
2014 Oct 14 03:03:37 --MDS-SW01 %PORT-5-IF_UP: %$VSAN 2%$ Interface fc1/28 is up in mode F
2014 Oct 14 03:17:25 --MDS-SW01 %MODULE-4-MOD_WARNING: Module 1 (serial: JAF1721BBMA) reported warning on ports 1/28-1/28 (Fibre Channel) due to MAC Bit error exceeded threshold in device 127 (de
2014 Oct 14 03:17:25 --MDS-SW01 %PORT-5-IF_DOWN_BIT_ERR_RT_THRES_EXCEEDED: %$VSAN 2%$ Interface fc1/28 is down (Error disabled - bit error rate too high)
2014 Oct 14 03:42:06 --MDS-SW01 %PORT-5-IF_DOWN_BIT_ERR_RT_THRES_EXCEEDED: %$VSAN 2%$ Interface fc1/27 is down (Error disabled - bit error rate too high)
2014 Oct 14 03:42:06 --MDS-SW01 %MODULE-4-MOD_WARNING: Module 1 (serial: JAF1721BBMA) reported warning on ports 1/27-1/27 (Fibre Channel) due to MAC Bit error exceeded threshold in device 127 (de
2014 Oct 14 06:23:29 --MDS-SW01 %PORT-2-IF_DOWN_LINK_FAILURE: %$VSAN 2%$ Interface fc1/18 is down (Link failure)
2014 Oct 14 06:27:39 --MDS-SW01 %PORT-2-IF_DOWN_LINK_FAILURE: %$VSAN 2%$ Interface fc1/18 is down (Link failure)
2014 Oct 14 06:27:39 --MDS-SW01 %PORT-5-IF_UP: %$VSAN 2%$ Interface fc1/18 is up in mode F
2014 Oct 14 06:31:42 --MDS-SW01 %PORT-4-IF_SFP_WARNING: Interface fc1/18, Low Rx Power Warning
2014 Oct 14 06:31:42 --MDS-SW01 %PORT-3-IF_SFP_ALARM: Interface fc1/18, Low Rx Power Alarm
2014 Oct 14 06:34:15 --MDS-SW01 %PORT-5-IF_DOWN_ADMIN_DOWN: %$VSAN 2%$ Interface fc1/27 is down (Administratively down)
2014 Oct 14 06:34:18 --MDS-SW01 %PORT-5-IF_DOWN_BIT_ERR_RT_THRES_EXCEEDED: %$VSAN 2%$ Interface fc1/27 is down (Error disabled - bit error rate too high)
2014 Oct 14 06:34:18 --MDS-SW01 %PORT-5-IF_UP: %$VSAN 2%$ Interface fc1/27 is up in mode F
2014 Oct 14 06:34:25 --MDS-SW01 %PORT-5-IF_DOWN_ADMIN_DOWN: %$VSAN 2%$ Interface fc1/28 is down (Administratively down)
2014 Oct 14 06:34:27 --MDS-SW01 %PORT-5-IF_DOWN_BIT_ERR_RT_THRES_EXCEEDED: %$VSAN 2%$ Interface fc1/28 is down (Error disabled - bit error rate too high)
2014 Oct 14 06:34:27 --MDS-SW01 %PORT-5-IF_UP: %$VSAN 2%$ Interface fc1/28 is up in mode F
2014 Oct 14 06:41:43 --MDS-SW01 %PORT-4-IF_SFP_WARNING: Interface fc1/18, Low Rx Power Warning cleared
2014 Oct 14 06:41:43 --MDS-SW01 %PORT-3-IF_SFP_ALARM: Interface fc1/18, Low Rx Power Alarm cleared
2014 Oct 14 07:24:15 --MDS-SW01 %MODULE-4-MOD_WARNING: Module 1 (serial: JAF1721BBMA) reported warning on ports 1/27-1/27 (Fibre Channel) due to MAC Bit error exceeded threshold in device 127 (de
2014 Oct 14 07:24:15 --MDS-SW01 %PORT-5-IF_DOWN_BIT_ERR_RT_THRES_EXCEEDED: %$VSAN 2%$ Interface fc1/27 is down (Error disabled - bit error rate too high)
2014 Oct 14 08:04:18 --MDS-SW01 %PORT-5-IF_DOWN_BIT_ERR_RT_THRES_EXCEEDED: %$VSAN 2%$ Interface fc1/28 is down (Error disabled - bit error rate too high)
2014 Oct 14 08:04:18 --MDS-SW01 %MODULE-4-MOD_WARNING: Module 1 (serial: JAF1721BBMA) reported warning on ports 1/28-1/28 (Fibre Channel) due to MAC Bit error exceeded threshold in device 127 (de
The error log file is full of events, like
followed by interface down / up,........
I see this for interface 1/19, 1/20, 1/18, 1/10, 1/25, 1/26.
The traffic flow is not going directly from disk (Netapp) to tape, but disk (Netapp) - Backup server - Tape ? correct ?
RX power warning : either you have wrong (single mode) patch cables; dirty connectors; broken SFP's; something at the physical layer is wrong.
If this is not fixed, you will have problems.
The traffic flow is flowing directly from disk (Netapp) to tape, through the Fabric (MDS). The two are zoned, accordingly. The type of traffic involved is NDMP data!
We will look at the physical layer and try to address the Rx Power warning, thank you for pointing that out.
Any word on the 'errDisable'?!
I think once you have fixed the physical problems (RX power issues), error disable will be gone.
I do not see any such errors on the ports that are involved in the design! I.e ports 23 and 27 or 28!
Do you suggest the Rx issue is system wide?!
Kindly advise the main suspects with the ErrDisable error?! The possible causes.
The following ports show RX power alarms:
FC 1/20, 1/12, 1/18, 1/10, 1/19
Can you please post the transceiver details ? show int fc1/28 transceiver
Cisco SFP's parts ? are the patch cables MMF ?
hi wdey,
below is infor on the transceivers connected to the library.
MDS-SW01# sh int fc1/28 transceiver
fc1/28 sfp is present
    Name is CISCO-AVAGO
    Manufacturer's part number is SFBR-5780APZ-CS2
    Revision is G2.3
    Serial number is AGA1719889N
    FC Transmitter type is short wave laser w/o OFC (SN)
    FC Transmitter supports short distance link length
    Transmission medium is multimode laser with 62.5 um aperture (M6)
    Supported speeds are - Min speed: 2000 Mb/s, Max speed: 8000 Mb/s
    Nominal bit rate is 8500 Mb/s
    Link length supported for 50/125mm fiber is 50 m
    Link length supported for 62.5/125mm fiber is 20 m
    Cisco extended id is unknown (0x0)
    No tx fault, rx loss, in sync state, diagnostic monitoring type is 0x68
    SFP Diagnostics Information:
        Temperature           :   0.00 C
        Voltage               : N/A
        Current               :   0.00 mA
        Optical Tx Power      :  N/A   dBm
        Optical Rx Power      :  N/A   dBm
        Tx Fault count  : 0
    Note: ++  high-alarm; +  high-warning; --  low-alarm; -low-warning
MDS-SW01# sh int fc1/27 transceiver
fc1/27 sfp is present
    Name is CISCO-AVAGO
    Revision is G2.3
    Serial number is AGA1719889Y
    No tx fault, no rx loss, in sync state, diagnostic monitoring type is 0x68
        Voltage               : N/A
        Current               :   0.00 mA
        Tx Fault count  : 0
Are your patch cables MMF 50/125 or 62.5/125 ?
Hi the cable is MMF 50/125! Any line of thinking?!
That's ok (max 50 m); do you have any sharp bend radius ?
Sorry wdey,
I was away for a while.
There are no sharp bends, that we have noticed.
Hey,
I tried change of SFPs from Finisar to Cisco Shortwave to not much effect! Only improvement was that a little more data was transferred (initially 50 GB now 250 GB) before the link drop!
Any thoughts?
hi,
