Error disabled - bit error rate too high on MDS switch
I have been trying to perform an NDMP backup between A HP LTO5 Ultrium Tape Library and Netapp with the MDS switch providing the fabric.
However, everytime I initiate the job, I experience this problem.
Below are some of the outputs on the concerned FC Ports:
MDS-SW01# sh int fc1/27
fc1/27 is down (Error disabled - bit error rate too high)
    Hardware is Fibre Channel, SFP is short wave laser w/o OFC (SN)
    Port WWN is 20:1b:54:7f:ee:e2:8d:00
    Admin port mode is auto, trunk mode is on
    snmp link state traps are enabled
    Port vsan is 2
    Receive data field Size is 2112
    Beacon is turned off
    5 minutes input rate 0 bits/sec, 0 bytes/sec, 0 frames/sec
    5 minutes output rate 0 bits/sec, 0 bytes/sec, 0 frames/sec
      263045 frames input, 12907156 bytes
        0 discards, 0 errors
        0 CRC,  0 unknown class
        0 too long, 0 too short
      4308477 frames output, 8677425352 bytes
        1 discards, 0 errors
      2 input OLS, 2 LRR, 0 NOS, 3 loop inits
      5 output OLS, 2 LRR, 1 NOS, 3 loop inits
    Interface last changed at Mon Oct 13 07:36:46 2014
MDS-SW01# sh int fc1/27 counters
fc1/27
      0 class-2 frames, 0 bytes
      263045 class-3 frames, 12907156 bytes
      0 class-f frames, 0 bytes
      0 discards, 0 errors, 0 CRC
      0 unknown class, 0 too long, 0 too short
      4308477 class-3 frames, 8677425352 bytes
    1 link failures, 1 sync losses, 1 signal losses
     9 BB credit transitions from zero
      32 receive B2B credit remaining
      0 transmit B2B credit remaining
      0 low priority transmit B2B credit remaining
What could be causing the issue and what is the solution?!
Thanks.
15 Replies 15
Hi Quijarro_felipe,
Thank you for the response. I have changed everything that could be changed and the link appears to hold up.
Even hardcoded the the speeds on the ports on the MDS switch.
Thank you all.
