errorDisabled status on a Cisco Nexus 5020 NX-OS 5.0(2)N2(1)
matthew.sanders
Any ideas how to NOT USE errdisable or allow the FCoE switch to put a port / interface / VFC  into an error disabled state?
I do not see any command(s) to NOT use this feature.
thanks
matt
Prashanth Krishnappa
You can disable errordisable condition only for certain causes. Here are the options.
F340.24.10-5548-1(config)# no errdisable detect cause ?
  all           Enable error detection on all cases
  inline-power  Enable error disable detection for POE
  link-flap     Enable error disable detection on linkstate-flapping
  loopback      Enable error disable detection on loopback
But you can enable recovery if needed
F340.24.10-5548-1(config)# errdisable recovery cause ?
  all                Enable timer to recover from all causes
  bpduguard          Enable timer to recover from BPDU Guard error disable state
  failed-port-state  Enable timer to recover from stp set port state failure
  inline-power       Enable timer to recover from POE disabled state
  link-flap          Enable timer to recover from linkstate flapping
  pause-rate-limit   Enable timer to recover from pause rate limit error disabled state
  udld               Enable timer to recover from udld error disabled state
Any particular condition you are after?
!! THAT's WHAT I WAS LOOKING FOR !!  Can't believe I overlooked using the "no.."
Thank you, it's set now to:
  NO ERRDISABLE DETECT CAUSE ALL
  exit
  copy run start
Done!
Being in DVT all I do is cause errors and failures, so I need it to not mess up a test by disabling an interface, never.
