Fabric Binding - Conflicting entries in the databases
virescent
Hi guys,
I've a new switch that I'd like to merge with the existing fabric.
I'm now working only with VSAN 1, and I have fabric-binding feature enabled and port-security feature disabled. I would like to configure fabric binding to allow merging it.
My configuration database has two entries, and the active database is empty:
switch# sh fabric-binding database active
Vsan   Logging-in Switch WWN     Domain-id
1      20:00:00:aa:aa:aa:aa:aa   0x9c(156) [Local]
1      20:00:00:bb:bb:bb:bb:bb      0x5(5)
[Total 2 entries]
WWN 20:00:00:aa:aa:aa:aa:aa is taken from "show wwn switch" output; 20:00:00:bb:bb:bb:bb:bb comes from the same output of another switch (with DomainID 5).
When I try to enable it, I receive this error and I cannot understand why:
switch(config)# fabric-binding activate vsan 1
Error for VSAN 1: Conflicting entries in the databases. Use force option to override.
switch(config)# fabric-binding database diff active vsan 1
Legend: "+" New Entry, "-" Missing Entry, "*" Possible Conflict Entry
-  1      20:00:00:aa:aa:aa:aa:aa   0x9c(156) [Local]
-  1      20:00:00:bb:bb:bb:bb:bb      0x5(5)
switch(config)# fabric-binding database diff conf vsan 1
+  1      20:00:00:aa:aa:aa:aa:aa   0x9c(156) [Local]
+  1      20:00:00:bb:bb:bb:bb:bb      0x5(5)
Even if I force activation, at the next change of the config DB I obtain the same error.
Can anybody help me please?
guijarro_felipe
hi,
Were you able to fix this behavior?
rgds
Hi, Cisco said that it's a bug in NX-OS 5.0.
