FC/FCoE from N5k to UCS/FI
SOcchiogrosso
Level 4
Level 4
I'm working on a new Data Center design, which very closely matches the hardware in the following document:
http://www.cisco.com/en/US/products/ps9670/products_configuration_example09186a0080c13e92.shtml
I'll have SANs directly attached to the N5k's, with UCS/FI where we are planning to utilize FCoE downstream to the UCS/FI environment.
Now, what I am curious about, is why in the above document (Which was updated in June 2013) there is a seperate FCoE port channel and another ethernet vPC. I am curious behind the reasoning behind this. Is there a limitation with FCoE over vPC links or is just a matter of keeping the traffic from fabric A away from fabic B?
Also I am assuming the document has an FCoE port-channel as opposed to a san-port-channel is for the additional throughput of 10Gb FCoE as opposed to the 8Gb FC links.
I see the disclaimer note about the 2x seperate links and the FI operating in NPIV mode from the FC perspective that just isn't not helping me.
CCNP, CCIP, CCDP, CCNA: Security/Wireless
Blog: http://ccie-or-null.net/
-- CCNP, CCIP, CCDP, CCNA: Security/Wireless Blog: http://ccie-or-null.net/
padramas
Hello Stephen,
One of the reason on why FCoE over vPC ( between UCS and N5K ) is not supported is that UCS currently allows all VSANs on all uplinks and cannot be pruned.
Padma
Makes sense, I was thinking that was the case. Thank you for the verification.
