Nexus 5500 NX-OS configuring logging equivalent to IOS
HUBERT RESCH
Level 3
Level 3
Hi we had as a default-config on our IOS-boxes
archive
log config
  logging enable
  notify syslog contenttype plaintext
  hidekeys
to log all executed commands in the log-file/syslog-server.
No we are looking for an equivalent configuration on Nexus 5000.
I could not find anything in the documentation.
Any idea how to achive this?
Thx
Hubert
bunce.jake
Hi Hubert,
Did you find the configuration to achieve this? I'm trying to get this working too.
Jacob
vdsudame
'show accounting log' output would show the accounting log directly on the switch. however it could roll over. For sending to logging/syslog server you can do this using AAA user. set the logging level for aaa to info (6). It should log all the commands to syslog server. also if you are using tacacs you can enable for AAA accounting and tacacs administration should show it.
Thanks, Vin.
Hubert, can you solve this? I have the same problem.
Thanks.-
