FC portchannel "invalidCfg"
JCcisco123
I have a 9216i’s (nxos 4.2) and a 6120 (ucs 2.0) that I am trying to configure a san-port-channel to port-channel with and I can’t get it working. The FC (F-NP) links work when they are not in a po, but when I try to form a port-channel I get “invalidCfg” on the MDS switch.
I am setting it up with only one link to start with.
What is wrong with this config or is their a bug?
The MDS switch has NPIV enabled.
UCS
interface san-port-channel 100
  channel mode active
  switchport mode NP
  switchport trunk mode on
interface fc2/1
  switchport mode NP
  channel-group 100 force
  no shutdown
MDS
interface port-channel 100
  channel mode active
  switchport mode F
  switchport speed 2000
  switchport rate-mode dedicated
  no shutdown
interface fc1/1
  switchport mode F
  no shutdown
MDS-1(config-if)# 2013 Oct 21 10:14:57 MDS-1 %PORT-5-IF_DOWN_INVALID_CONFIG: %$VSAN 1%$
Interface fc1/1 is down(Error disabled - Possible PortChannel misconfiguration)
MDS
Interface  Vsan   Admin  Admin   Status          SFP    Oper  Oper   Port
                  Mode   Trunk                          Mode  Speed  Channel
                         Mode                                 (Gbps)
fc1/1      1      F      on      invalidCfg       swl    --           100
UCS
                         Mode                                 (Gbps)
fc2/1      1      NP     on      notConnected     swl    --           100
8 Replies 8
dynamoxxx
Level 5
Level 5
i assume FI are running host-end mode ? Did you enable fport-channel-trunk on 9216 (hopefully it supports it)?
feature fport-channel-trunk
@dynamoxxx
@dynamoxxx
All interfaces on both devices have their membership in vsan 1.
FI has “FC Uplink Trunking” enabled and is running EHM.
fport-channel-trunk   1         enabled
fport-channel-trunk is enabled on 9216 ?
@dynamoxxx
@dynamoxxx
Yes. No matter what I do, or how I configure it on either side. I keep getting the MDS fc interface being error disabled.
2013 Oct 21 14:23:10 MDS-1 %PORT-5-IF_DOWN_INVALID_CONFIG: %$VSAN 1%$ Interface fc1/1 is down(Error disabled - Possible PortChannel misconfiguration)
MDS 9509
  channel mode active
  switchport trunk mode off
# sh vsan membership interface port-channel 10
port-channel 10
        vsan:114
        allowed list:1-4078,4080-4093
FI
  channel mode active
  switchport mode NP
#sh vsan membership interface san-port-channel 10
san-port-channel 10
        vsan:114
port-channel on both sides have been added to VSAN 114, as you can see i am not trunking multiple VSANs.
@dynamoxxx
@dynamoxxx
I think I know what the problem is. 9216i's default line card are gen 1 and do not support f-port-trunk functionality. I am going to buy a gen 2 line card x9148 and put it in. I have been told these will work.
interesting, they allow you to enable software features without checking hardware compatibility.
@dynamoxxx
@dynamoxxx
Did you ever resolve this? I am running into the same thing but have the x9148 2nd gen modules. Any help would be great, figure it is not compatible with the FI as I am able to do port channels with 5Ks and with another MDS 9216i with the second gen module.
