04-17-2008 06:58 AM
Have anyone used successfully the fcanalyzer remote command?. I have configured the mds and the ethereal rpcap interface as explained in the documentation but no joy.
Edmundo
04-17-2008 11:41 PM
It was broken between SAN-OS 3.0(2) and 3.0(3b).
04-18-2008 12:55 AM
Thanks for the reply. I am using 1.3.6. When I try to configure Etheral it cannot connect to the MDS. There is connectivity between the PC and the MDS.
Edmundo
04-18-2008 02:22 PM
Do you have any IP Services line cards in your switch?
Cheers
Andrew
04-19-2008 07:24 AM
Thanks for your reply.
Yes. I have the IPS-8.
Edmundo
04-21-2008 02:41 AM
G'day,
are you trying to remote fcanalyzer to a device which is on the same subnet as a port on your IPS or have a static route moving traffic through to your remote machine via a IPS port? (I suspect yes 🙂
I'm not sure of a work around but one of the Cisco guys might know a work around on here or you should log a TAC case 🙂
Cheers
Andrew
04-23-2008 04:50 AM
Hi Andrew,
Thanks for the ideas. Unfortunately I don't have the MDS under smarnet so I cannot open a TAC. Do you have it working?
04-28-2008 04:32 PM
G'day,
Unfortunately I could not get it working to a subnet which was being sent over a IPS port 😞
The only way around for me was to have a workstation not on the same subnet as those on used by the IPS.
Cheers
Cheers
Andrew
04-28-2008 11:03 PM
Thanks Andrew. I will try this workaround.
Edmundo
05-08-2008 04:19 PM
Any luck? 🙂
05-22-2008 04:52 AM
No. I gave up. I tried with different switches and son-os but no joy.
Edmundo
