fcanalyzer remote
ebodero
Have anyone used successfully the fcanalyzer remote command?. I have configured the mds and the ethereal rpcap interface as explained in the documentation but no joy.
Edmundo
10 Replies 10
dmcloon
It was broken between SAN-OS 3.0(2) and 3.0(3b).
Thanks for the reply. I am using 1.3.6. When I try to configure Etheral it cannot connect to the MDS. There is connectivity between the PC and the MDS.
Edmundo
Do you have any IP Services line cards in your switch?
Cheers
Andrew
Thanks for your reply.
Yes. I have the IPS-8.
Edmundo
G'day,
are you trying to remote fcanalyzer to a device which is on the same subnet as a port on your IPS or have a static route moving traffic through to your remote machine via a IPS port? (I suspect yes :)
I'm not sure of a work around but one of the Cisco guys might know a work around on here or you should log a TAC case :)
Cheers
Andrew
Hi Andrew,
Thanks for the ideas. Unfortunately I don't have the MDS under smarnet so I cannot open a TAC. Do you have it working?
G'day,
Unfortunately I could not get it working to a subnet which was being sent over a IPS port :(
The only way around for me was to have a workstation not on the same subnet as those on used by the IPS.
Cheers
Cheers
Andrew
Thanks Andrew. I will try this workaround.
Edmundo
Any luck? :)
No. I gave up. I tried with different switches and son-os but no joy.
Edmundo
