FCIP tunnels configuration and validation
vjmendoza
Level 4
Level 4
I have configured FCIP tunnels before where each tunnel is placed in its own subnet.  I couldn't find any documentation that would show that this has to be the case or this is best practice.
I am configuring a scenario where there are two pairs of MDS, one pair per Data Center (Fabric A and B)
So for DC01
Fabric A switch ip address for each interface (there are four gigabit interfaces) are the following (IPs have been changed but concept should remain the same):
Switch A - DC01
GigabitEthernet6/1 - 1.1.1.1
GigabitEthernet6/2 - 1.1.1.2
GigabitEthernet6/3 - 1.1.1.3
GigabitEthernet6/4 - 1.1.1.4
Switch B - DC01
GigabitEthernet6/1 - 1.1.1.5
GigabitEthernet6/2 - 1.1.1.6
GigabitEthernet6/3 - 1.1.1.7
GigabitEthernet6/4 - 1.1.1.8
Switch A - DC02
GigabitEthernet6/1 - 2.2.2.1
GigabitEthernet6/2 - 2.2.2.2
GigabitEthernet6/3 - 2.2.2.3
GigabitEthernet6/4 - 2.2.2.4
Switch B - DC02
GigabitEthernet6/1 - 2.2.2.5
GigabitEthernet6/2 - 2.2.2.6
GigabitEthernet6/3 - 2.2.2.7
GigabitEthernet6/4 - 2.2.2.8
Does anyone see any issues that might arise if tunnels are not necessarily placed in their own subnet?
I have added the full configuration of Switch A and B for DC01 at the very bottom for further clarification.
Switch DC01_A
fcip profile 1
ip address 1.1.1.1
fcip profile 2
ip address 1.1.1.2
fcip profile 3
ip address 1.1.1.3
fcip profile 4
ip address 1.1.1.4
vsan database
vsan 10
interface port-channel 10
switchport trunk allowed vsan 10
interface fcip1
channel-group 10 force
no shutdown
use-profile 1
peer-info ipaddr 2.2.2.1
interface fcip2
no shutdown
use-profile 2
peer-info ipaddr 2.2.2.2
interface fcip3
channel-group 11 force
no shutdown
use-profile 3
peer-info ipaddr 2.2.2.3
interface fcip4
no shutdown
use-profile 4
peer-info ipaddr 2.2.2.4
interface GigabitEthernet6/1
ip address 1.1.1.1 255.255.255.0
switchport mtu 3000
no shutdown
interface GigabitEthernet6/2
ip address 1.1.1.2 255.255.255.0
switchport mtu 3000
no shutdown
interface GigabitEthernet6/3
ip address 1.1.1.3 255.255.255.0
switchport mtu 3000
no shutdown
interface GigabitEthernet6/4
ip address 1.1.1.4 255.255.255.0
switchport mtu 3000
no shutdown
Switch DC01_B
fcip profile 1
ip address 1.1.1.5
fcip profile 2
ip address 1.1.1.6
fcip profile 3
ip address 1.1.1.7
fcip profile 4
ip address 1.1.1.8
vsan database
vsan 10
interface fcip1
no shutdown
use-profile 1
peer-info ipaddr 2.2.2.5
interface fcip2
no shutdown
use-profile 2
peer-info ipaddr 2.2.2.6
interface fcip3
no shutdown
use-profile 3
peer-info ipaddr 2.2.2.7
interface fcip4
no shutdown
use-profile 4
peer-info ipaddr 2.2.2.8
ip address 1.1.1.5 255.255.255.0
switchport mtu 3000
no shutdown
ip address 1.1.1.6 255.255.255.0
switchport mtu 3000
no shutdown
ip address 1.1.1.7 255.255.255.0
switchport mtu 3000
no shutdown
ip address 1.1.1.8 255.255.255.0
switchport mtu 3000
no shutdown
vjmendoza
Level 4
Level 4
I forgot to mention that I will have host static routes for reachability
So from Switch A DC01
ip route 2.2.2.1 255.255.255.255 interface gigabitethernet 6/1
ip route 2.2.2.2 255.255.255.255 interface gigabitethernet 6/2
ip route 2.2.2.3 255.255.255.255 interface gigabitethernet 6/3
ip route 2.2.2.4 255.255.255.255 interface gigabitethernet 6/4
Create a port-channel with 3 interfaces is not a best practice, it works, but you don't have a good load balancing among them.
To high availability you may also use vrrp or even leave two fc-port-channels as you did.
Set up the write acelerator and windowing options is always good.
Regards.
Richard
