FCoE configuration in Nexus 5K
SabarnaDeb
Dear All,
After configuring FCoE, we are getting "Trunk vsans (initializing)             (VSAN NO.)". We have followed the below steps:-
1. "switchport mode trunk" for physical port where FCoE cable connected.
2. spanning-tree port type edge trunk
3. Allow respective VLAN including FCoE VLAN
4. VFC created.
5. Bind VFC with Physical Ethernet Port
6. VSAN is already added in VLAN
7. Associate VFC to VSAN
8. no shutdown command for VFC
we didn't install ESXi OS in that server.
Please check below config:-
XXXXXXXXX# show interface vfc 512
vfc512 is trunking
    Bound interface is Ethernet1/9
    Hardware is Ethernet
    Port WWN is XX:XX:XX:XX:XX:XX:XX
    Admin port mode is F, trunk mode is on
    snmp link state traps are enabled
    Port mode is TF
    Port vsan is 501
    Trunk vsans (admin allowed and active) (501)
    Trunk vsans (up)                       (501)
    Trunk vsans (isolated)                 ()
    Trunk vsans (initializing)             ()
    1 minute input rate 8209792 bits/sec, 1026224 bytes/sec, 1221 frames/sec
    1 minute output rate 4658600 bits/sec, 582325 bytes/sec, 1572 frames/sec
      120678021178 frames input, 189061039874284 bytes
        0 discards, 0 errors
      222141855763 frames output, 348939068899784 bytes
    last clearing of "show interface" counters never
    Interface last changed at Wed Apr 18 14:23:14 2012
Any idea...help why we are getting initializing??
Message was edited by: Sabarna Deb
16 Replies 16
Hi Luke,
Please find the output.
And also VFC is not showing in show flogi database.
Now it is working. We have enable FCoE in server bios level.
