fcoe-npv vs. fcoe
robad
We are running:
Nexus9000 C93360YC-FX2
NXOS: version 10.3(2)
We've installed the feature-set "fcoe", and now I see on the official guides that I need to install "fcoe-npv"
But, it gives me this error :
n9k-b(config)# no install feature-set fcoe
feature-set can not be uninstalled because its enabled on one or more VDCs(0x40aa001c)
1. Do I really need the "fcoe-npv" instead of just "fcoe" ?
2. If so, How can I achieve it now ?....
** update -
What I need is just to be able to connect FC storage (Like HPE Nimble) to this N9K, and also, our FI will be connected to it, with FCoE Uplinks
Thanks in advance
2 Accepted Solutions
M02@rt37
Hello @robad,
The "fcoe" feature set is typically used for traditional FCoE scenarios where the Nexus switch itself acts as an FCoE forwarder.
On the other hand, the feature "fcoe-npv" is used when the Nexus switch needs to operate in NPV (N-Port Virtualization) mode, often in scenarios where you want the Nexus switch to act as an FCoE transit switch in front of a core FC switch (like a Cisco MDS) without doing full FC routing.
To sum up: if it's acting as a transit switch between FCoE and FC, you might need "fcoe-npv." If you're connecting FC storage directly to the Nexus switch, you may not need "fcoe-npv."
Best regards
5 Replies 5
M02@rt37
Hello @robad,
Best regards
robad
thanks both of you guys !!
so, we are not using MDS
We just want to be able that the VMs from hosted on our UCS (FI) , that is connceted to this N9K, will be able to access to HPE storage, that is also connected to the same N9K.
So I understanf I can keep FCoE if it's the state - right ?
@robad
Right!
Best regards
robad
thanks all of you guys !
