10-10-2023 02:40 AM - edited 10-10-2023 02:43 AM
We are running:
Nexus9000 C93360YC-FX2
NXOS: version 10.3(2)
We've installed the feature-set "fcoe", and now I see on the official guides that I need to install "fcoe-npv"
But, it gives me this error :
n9k-b(config)# no install feature-set fcoe
feature-set can not be uninstalled because its enabled on one or more VDCs(0x40aa001c)
1. Do I really need the "fcoe-npv" instead of just "fcoe" ?
2. If so, How can I achieve it now ?....
** update -
What I need is just to be able to connect FC storage (Like HPE Nimble) to this N9K, and also, our FI will be connected to it, with FCoE Uplinks
Thanks in advance
Solved! Go to Solution.
10-10-2023 03:54 AM
Hello @robad,
The "fcoe" feature set is typically used for traditional FCoE scenarios where the Nexus switch itself acts as an FCoE forwarder.
On the other hand, the feature "fcoe-npv" is used when the Nexus switch needs to operate in NPV (N-Port Virtualization) mode, often in scenarios where you want the Nexus switch to act as an FCoE transit switch in front of a core FC switch (like a Cisco MDS) without doing full FC routing.
To sum up: if it's acting as a transit switch between FCoE and FC, you might need "fcoe-npv." If you're connecting FC storage directly to the Nexus switch, you may not need "fcoe-npv."
10-10-2023 04:18 AM
check my old thread :
https://community.cisco.com/t5/storage-networking/fcoe-vs-fcoe-npv/td-p/3773774
coming back to your 9K requirement - check below model (Supported Hardware) and SFP requirement :
10-10-2023 03:54 AM
Hello @robad,
10-10-2023 04:18 AM
10-10-2023 04:32 AM
thanks both of you guys !!
so, we are not using MDS
We just want to be able that the VMs from hosted on our UCS (FI) , that is connceted to this N9K, will be able to access to HPE storage, that is also connected to the same N9K.
So I understanf I can keep FCoE if it's the state - right ?
10-10-2023 04:54 AM
10-10-2023 05:09 AM
thanks all of you guys !
