Fiber SFP's in SMIP modules DS-X9304-SMIP DS-X9308-SMIP
bfeeny
In the list of gbic's you are to use for SMIP modules found here:
http://www.cisco.com/en/US/prod/collateral/ps4159/ps6409/ps4358/product_data_sheet09186a00801bc698.html
They say you can use DS-SFP-FCGE-SW. They call this a tri-rate GBIC, saying it can operate 1/2GB FC or 1GB Ethernet.
Is there anything really special about this GBIC? I mean, my experience is that just about any 1/2GB FC GBIC can run short haul fiber ethernet (850nm). I assume this is just marketing, or am I missing something? I just plugged in a rather generic FC gibc (agilent or finisar or the like) and I plugged it into a SMIP and could ping across just fine with no errors.
inch
Level 3
Level 3
I'm not sure about modern SFP's but older FC ones would not work as ethernet.
It might be the standard now for all of them to be tri-rate.
I'll have a look around for some old sfp's and give them a go...
Ok, I think I just got very lucky. I happen to use a ton of Finisar FTRJ8519P1BNL which happen to support 1/2GB FC as well as Gig Ethernet.
I've found some older FC sfp's and the certainly don't do ethernet :\
