fip-snooping vlan-discovery returns nothing
r.s.alavi
Hello every one.
I have two IBM BladeCenter H Series each one equiped with seven IBM HS22, as an I/O device one Qlogic 2 10 GE CNA addpater has been installed on IBM HS22s. in I/O bay 7 and 9 Nexus 4001i has been installed, These NX4001is are connected to two Nexus 5010 and from there Nexus 5010 are connected to MDS9134 and EMC VNX 5300 (FCoE). I have been trying to configure the whole network using FCoE for storage access on HS22 servers VMware ESX 4U1 is installed. after three weeks of strugle i still can not see any mac address when I issue command "fip-snooping vlaqn-discovery".
I have minimized my whole topology into one single link between Nexus 4001i and Nexus 5010 and still it's not working, when i enable the debug for dcbx i see the following error:
170) Event:E_DEBUG, length:77, at 76332 usecs after Sat Feb 25 16:12:29 2012
    [102] dcx_lldp_get_lls:429 Could not find LLDP Feature on if_index=0x1a003000
even though when i check LLDP on all interfaces it shows it is enabled and receiving and sending traffics.
when i issue "show mac-address-table" on nexus 4001i, i can not see any macc address. follwing is the configuration for both switches:
Nexus 4001i
Nexus 5010
version 4.1(2)E1(1f)
feature telnet
feature lacp
feature fip-snooping
ip domain-lookup
ip host MapNX4001-B1-7 192.168.10.154
switchname MapNX4001-B1-7
vrf context management
  ip route 0.0.0.0/0 172.27.66.1
vlan 1
vlan 9
  fip-snooping enable
interface Ethernet1/1
  switchport mode trunk
  switchport trunk allowed vlan 1,9
  spanning-tree port type edge trunk
  speed auto
interface Ethernet1/2
  speed auto
interface Ethernet1/3
  speed auto
interface Ethernet1/4
  speed auto
interface Ethernet1/5
  speed auto
interface Ethernet1/6
  speed auto
interface Ethernet1/7
  speed auto
interface Ethernet1/8
  shutdown
  speed auto
interface Ethernet1/9
  shutdown
  speed auto
interface Ethernet1/10
  shutdown
  speed auto
interface Ethernet1/11
  shutdown
  speed auto
interface Ethernet1/12
  shutdown
  speed auto
interface Ethernet1/13
  shutdown
  speed auto
interface Ethernet1/14
  shutdown
  speed auto
interface Ethernet1/15
  shutdown
  speed 10000
interface Ethernet1/16
  shutdown
  speed 10000
interface Ethernet1/17
  !!! Link to Nexus 5010
  switchport trunk allowed vlan 9
  fip-snooping port-mode fcf
  spanning-tree port type trunk
  speed 10000
interface Ethernet1/18
  shutdown
  speed 10000
interface Ethernet1/19
  shutdown
  speed 10000
interface Ethernet1/20
  shutdown
  speed 10000
interface mgmt0
  ip address 192.168.10.154/24
interface mgmt1
boot kickstart bootflash:/n4000-bk9-kickstart.4.1.2.E1.1f.bin
boot system bootflash:/n4000-bk9.4.1.2.E1.1f.bin
system health loopback frequency 60
ip route 0.0.0.0/0 192.168.10.100
version 5.0(3)N2(1)
feature fcoe
feature telnet
feature lldp
ip domain-lookup
hostname MapNX5010-1
class-map type qos class-fcoe
class-map type queuing class-all-flood
  match qos-group 2
class-map type queuing class-ip-multicast
  match qos-group 2
class-map type network-qos class-all-flood
  match qos-group 2
class-map type network-qos class-ip-multicast
  match qos-group 2
vlan 1
vlan 9
  fcoe vsan 9
vsan database
  vsan 9
interface fc2/1
interface fc2/2
interface fc2/3
interface fc2/4
interface fc2/5
interface fc2/6
  shutdown
  shutdown
  shutdown
  shutdown
  shutdown
  shutdown
  !!! Link to Nexus 4001i
  shutdown
  shutdown
  shutdown
  shutdown
  shutdown
  shutdown
  shutdown
  shutdown
  shutdown
  shutdown
  shutdown
  shutdown
  shutdown
interface mgmt0
  ip address 192.168.10.151/24
line console
line vty
boot kickstart bootflash:/n5000-uk9-kickstart.5.0.3.N2.1.bin
boot system bootflash:/n5000-uk9.5.0.3.N2.1.bin
interface fc2/1
interface fc2/2
interface fc2/3
interface fc2/4
interface fc2/5
interface fc2/6
MapNX5010-1#
MAK
On 5K
Down link
  switchport trunk allowed vlan 1,9          < --- Remove
On 4K
Up-link
  switchport trunk allowed vlan 9          < ---  Remove
  spanning-tree port type trunk          < ---  Remove
  speed 10000
On Server interfaces  e1/1-7
switchport trunk native vlan 1               < ----  Add
  speed auto
- shut/no shut after modify these paramenters
- Make sure QOS add to N4K
policy-map type queuing policy-fcoe-bandwidth
  class type queuing 1p7q4t-out-q-default
    bandwidth percent 50
  class type queuing 1p7q4t-out-pq1
    bandwidth percent 7
  class type queuing 1p7q4t-out-q2
    bandwidth percent 7
  class type queuing 1p7q4t-out-q3
    bandwidth percent 7
  class type queuing 1p7q4t-out-q4
    bandwidth percent 7
  class type queuing 1p7q4t-out-q5
    bandwidth percent 7
  class type queuing 1p7q4t-out-q6
    bandwidth percent 7
  class type queuing 1p7q4t-out-q7
    bandwidth percent 7
class-map type network-qos Jumbo1
  match cos 4
class-map type network-qos class-fcoe
  match cos 3
class-map type network-qos class-non-fcoe
  match cos 0-2,4-7
policy-map type network-qos Jumbo
  class type network-qos Jumbo1
    mtu 9216
policy-map type network-qos policy-fcoe
  class type network-qos class-fcoe
    pause no-drop
    mtu 2500
  class type network-qos class-non-fcoe
system qos
  service-policy type network-qos policy-fcoe
  service-policy type queuing output policy-fcoe-bandwidth
11 Replies 11
fb_webuser
Level 6
Level 6
I don't see any configuration for your vfc interface?
To bind to a MAC address when the CNA is remotely connected through a DCB bridging device such as a Nexus 4000 to the Nexus 5x00.
config on the 5k:
(config-if)# interface vfc n
(config-if)# bind mac-address 00:0a:00:00:00:36
Posted by WebUser Adriaan Steyn
Thank you Adriaan,
As you mentioned correctly i need to create a vfc and bind it to discoverd MACs of Server's CNAs, but that is exactly where i got stuck, when i issue the command "fip-snooping vlan-discovery" to get the resolved mac address for vfc binding, the comannd does not have ny output.
On 5K
Down link
On 4K
Up-link
  speed 10000
  speed auto
    bandwidth percent 7
    bandwidth percent 7
    bandwidth percent 7
    bandwidth percent 7
    bandwidth percent 7
    bandwidth percent 7
    bandwidth percent 7
  match cos 4
  match cos 3
  match cos 0-2,4-7
    mtu 9216
    pause no-drop
    mtu 2500
system qos
Dear Vu,
Thank you so much for the help, the problem has been resolved, I guess QoS Policy resolved the issue. the system in now working fine. Thanx again .
CoolMAK
Hi All,
I also encounter the same issue. Is this N4k QOS setting is Cisco recommended one?
Can anyone provide Cisco document for QOS requirement for N4k FIP snooping/ FCOE?
Ye
Hi Vu,
Thanks for your kind response. I saw this one but it's general guide how to configure. For customer point of view, they need Cisco's confirmation as it's production network.
For N7k and N5k, Cisco mention this QOS requirement for FCOE very clearly. But for N4k, there is no such info, I also check below design guide, Cisco didn't mention about QOS requirement for N4k.
http://www.cisco.com/en/US/prod/collateral/switches/ps9441/ps10596/deployment_guide_c07-574724.pdf
Thank you,
Ye
Hello Ye,
Confirmed QOS is required for FCOE fip-snooping
http://www.cisco.com/en/US/partner/docs/switches/datacenter/nexus4000/nexus4000_i/sw/configuration/guide/rel_4_1_2_E1_1/fip.html
Configuring QoS
QoS must be configured for FCoE before FIP snooping is enabled. MTU, PFC, and ETS are required for FIP snooping. During initial configuration of the switch, QoS is configured by default if you configure FCoE at the time. If you want to change the default QoS configuration, you should configure QoS.
Hi Vu,
That means there will be QOS config if we configured FCOE during the initial setup. Can we assume that the below qos setting is the default config requirement?
As all our customer's N4k are in production and we need to make sure not to be any impact. Also not possible to get a spare to test, that's why, we need Cisco confirmation or official document.
    bandwidth percent 7
    bandwidth percent 7
    bandwidth percent 7
    bandwidth percent 7
    bandwidth percent 7
    bandwidth percent 7
    bandwidth percent 7
  match cos 4
  match cos 3
  match cos 0-2,4-7
    mtu 9216
    pause no-drop
    mtu 2500
system qos
  service-policy type queuing output policy-fcoe-bandwidth policy-map type queuing policy-fcoe-bandwidth
Thanks you so much!
Ye
Hello Ye,
confirmed, the QOS listed above is a requirement for FCOE
thanks
Vu
Thanks a lot. After enabling QOS on N4k site, VSANs are UP on N5k site.
Ye
