How to monitor throughput on fc switch ports
santoshsm
We recently started using the cisco nexus 5000 switch.
Previosuly we were using brocade switch.
In order to monitor the throughput on the switch ports, we used the command >perfportshow
output:
  0    1    2    3    4    5    6    7    8    9   10   11   12   13   14   15 Total
52m   0    0   79m  79m  52m   0    0    0    0    0    0    0    0    0    0  262m
It used to depict the throughput on each of its 16 ports.
Do we have a similar command on a cisco nexus 5000 swithc to monitor the throughput dynamically on the ports.
Any guidance appreciated.
Thanks.
5 Replies 5
User_4444_2
On 9509 switches I use " sh int counters brief module *" * for the number of each Module in this case 2 and I get the following output.
sh int counters brief module 2
Interface          Input (rate is 5 min avg)      Output (rate is 5 min avg)
                   Rate     Total                 Rate     Total
                   MB/s     Frames                MB/s     Frames
fc2/1                 0     1                        0     1
fc2/2                 0     1224699488               0     3429684064
fc2/3                 0     1                        0     1
fc2/4                 0     1214147374               0     1927673039
fc2/5                 0     1                        0     1
fc2/6                 0     1                        0     1
fc2/7                 0     1                        0     1
fc2/8                 1     11510254385             11     19770450459
fc2/9                18     58026366094             44     220233153527
fc2/10               19     17008767450             19     35833527274
fc2/11                0     39851510969              0     156730340768
fc2/12                0     1                        0     1
fc2/13                0     1                        0     1
fc2/14                0     3543781575               0     16305763606
fc2/15                0     1                        0     1
fc2/16                0     1                        0     1
fc2/17                0     1                        0     1
fc2/18                0     1                        0     1
fc2/19                0     1                        0     1
fc2/20                0     1                        0     1
fc2/21                0     1                        0     1
fc2/22                0     1                        0     1
fc2/23                0     1                        0     1
fc2/24                0     32036382020              0     97783387882
fc2/25                0     30948988897              0     103928942588
fc2/26                0     1                        0     1
fc2/27                0     9660166159               0     16594964293
fc2/28                0     1                        0     1
fc2/29                0     8288591099               0     12351752310
fc2/30                0     3817420276               1     18060412406
fc2/31                0     8693113679               2     15227020605
fc2/32                2     18464865368              1     26363448965
fc2/33                0     1                        0     1
fc2/34                0     1                        0     1
fc2/35                0     1                        0     1
fc2/36                0     1                        0     1
fc2/37                0     1                        0     1
fc2/38                0     1                        0     1
fc2/39                0     1                        0     1
fc2/40                0     1                        0     1
fc2/41                0     359100865497             0     64890519049
fc2/42                0     1                        0     1
fc2/43                0     310679253243             0     77398281413
fc2/44                0     1                        0     1
fc2/45                3     27809296255              0     42985060915
fc2/46                0     15946062800              0     32744671193
fc2/47                1     27140980991              0     71032538176
fc2/48                0     23496252397              0     48801426244
Thanks Roy.
But is that dynamic.. ?
What i mean is - in the portperfshow command, it systematically displays the throughput on the ports and that too in real time with a interval of 1 second.
You just fire the command and sit back and you will get per second throughput stats.
does the above has same capabilities?
Thanks.
I know that Brocade command from many years ago, no it doesn't do the automatic refresh. You can also use " sh int aggregate-counters brief" for all the modules usage but that doesn't refresh either. I think you could script something to re-run either command every 5 minutes thou.
Cheers
You can try Device Mangaer summary tab.
It's #3 in this link.http://www.cisco.com/en/US/docs/switches/datacenter/mds9000/sw/5_2/configuration/guides/fund/DCNM-SAN-LAN_5_2/dm.html#wp254943
The poll interval might be 10 or 30 seconds. Select Util%.
David
After the port type has been changed from Ethernet to FC, the FC port will not be enabled on the switch until FCOE feature is enabled:
N5K(config)#feature FCOE
C license checked out successfully
fc_plugin extracted successfully
FC plugin loaded successfully
FCoE manager enabled successfully
FC enabled on all modules successfully
Enabled FCoE QoS policies successfully
