IBM Qualification and MDS 9148s switrches
I have a customer who is looking to use a series of mds 9148s switches as Edge  / TOR switches to a core consisting of a single MDS 9710
They however require the code on the core switches to be IBM FICON Qualified
There present MDS 9710 environment is on code Nexus 6.2(5a) which is supported and qualified by IBM
Best practice is to have all switches in a Fabric on the same supported code level
Looking at the support matrix a MDS 9148s lowest code level listed is 6.2(9) which I cannot find as supported by IBM or qualified
Therefore is there a version of code 6.2(5a) that can be used on a 9148s, I suspect the answer to this is no, and code for a standard 9148 which will support 6.2(5a) will be incompatible with the 9148s switch type
Secondly other than 6.2(5a) and 6.2(11c) are there any other code level that anybody knows which have been qualified by IBM for FICON support
http://www.cisco.com/c/en/us/td/docs/switches/datacenter/mds9000/interoperability/matrix/intmatrx.pdf
Paresh Gupta
Your best option is to use 6.2(11c). However, if the customer is happy with 6.2(5a), I would take a slight deviation from running same code version everywhere. MDS 9148S should be fine with later code versions.
Paresh Gupta
Paresh
I cam e to the same conclusion, customer has accepted that we will need to move to the later code version to maintain support and keep codes in lock step so we are good, thanks for confirming the details
