iSCSI and NX-OS
bwindle66
    Thrown into a project starting Monday with 2 5548 switches and the customer wants to do SMB, iSCSI, and NFS. It is coming with a layer 3 card so I get the NFS and SMB. But isn't there a feature to be enabled with NX-OS or lun database to set up? Haven't turned up much in the configuration guide and I'm beginning to this it's just going to be ethernet connectivity throughout, so just a sanity check if anyone has done iscsi on a nx-os is what I am looking for.
krun_shah
I do not think any special needs to be done on a network switch which just switches iscsi frames from one port to another.
You can do some QoS and set MTU and queue-limit etc. it this switch is also shared with data traffic. Following is one type of example where servers has to mark the iscsi frames with CoS 2 and you can set the value of MTU.
class-map type qos iSCSI-qos-class
match cos 2
policy-map type qos iSCSI-qos-policy
class iSCSI-qos-class
set qos-group 2
class-map type queuing iSCSI-queuing-class
match qos-group 2
class-map type network-qos iSCSI-network-class
match qos-group 2
policy-map type network-qos iSCSI-network-policy
class type network-qos iSCSI-network-class
mtu 9216
system qos
service-policy type qos input iSCSI-qos-policy
service-policy type network-qos iSCSI-network-policy
krun_shah
match cos 2
set qos-group 2
match qos-group 2
match qos-group 2
mtu 9216
system qos
Also to set up MTU on the SVI vlan interface.
Interface vlan 10
mtu 9216
Thanks!
Vincent La Bua
Don't route the iscsi and do testing with and without aggregated links to hosts and storage. They can sometimes affect the session handling and cause performance issues.
