Jumbo Frames - nexus 5010
Abilio Cardoso
how to configure jumbo frames on the Nexus 5010 with Netapp?
6 Replies 6
Oleksandr Nesterov
Hello Abillo
All you need to do is put this configuration on all your nexus 5ks:
switch(config)#policy-map type network-qos jumbo
switch(config-pmap-nq)#class type network-qos class-default
switch(config-pmap-c-nq)#mtu 9216
switch(config-pmap-c-nq)#exit
switch(config-pmap-nq)#exit
switch(config)#system qos
switch(config-sys-qos)#service-policy type network-qos jumbo
This will globally enable jumbo frames.
To  verify whether it works, do a "show int eth x/y", you should see the jumbo counters increasing.
Also  note that the mtu won't change on the interface itself, its a global  command, not a 'per interface' command. But thats ok, even if mtu says  1500 it can still accept jumbo frames if you have the global config  applied.
Example:
Ethernet1/1 is up
  RX
      0 unicast packets  1221713 multicast packets  2644 broadcast packets
      1224357 input packets  91236171 bytes
---> 458 jumbo packets  0 storm suppression packets
      0 giants  0 input error  0 short frame  0 overrun   0 underrun
      0 watchdog  0 if down drop
      0 input with dribble  0 input discard
      0 Rx pause
Please refer to this link:
http://www.cisco.com/en/US/products/ps9670/products_configuration_example09186a0080b44116.shtml
Hope that will help you.
Alex
Thank you Alex!!!
I applied the setting in N5k and is working normally.
You are welcome Abilio.
Alex
Can I ask one question that sort of applies to this?  Is it possible to setup jumbo frames on a Nexus 5010 by creating a new VLAN while still leaving the other VLANs on the switch without jumbo frames enabled?  We'd like to use 10 GB connections with jumbo frames to our filer while using the 1 GB ports to connect to other devices.  Any assistance would be appreciated.
Jeff
You can change MTU for traffic using different COS values, for example
if you can mark on the server side a cos value on this vlan, then you
can apply the MTU change for it, but there is vlan matching criteria on
the switch to adjust the MTU.
The other way to check this is ping from NetApp to the Nexus switch with a packet size of 10000.
netapp>ping -s packetsize 10000
