MDS 9216i - FCIP trunkNotFullyActive
cdayton
FCIP 11 appears to be operational, but Device Manager is reporting "trunkNotFullActive" in the Failure Cause column. Has anyone experienced passed failures hanging around forever?
Running on 3.2.(2c).
amritpatek
Level 6
Level 6
'trunkNotFullyActive' indicates that some of the VSANs which are common with the peer are not up. When the When trunkNotFullyActive ( 108 ), DM will show yellow square. To be able to see what exactly the status reason, enable the tooptip, the status reason is shown as part of the tooltip of every port.
amritpatek
Level 6
Level 6
