MDS size of memory allocated for naming ?
jjpeyrache
hi
what is the maximum size can be allocated for
port naming and aliasing of MDS family ?
customer asked because on brocade switches
this size is limited and in huge configurations
with lot of ports in fabric and very long naming
aka (portofswitchfootoservertoo1) it should be a problem
so
are this same restriction on mds family ?
thanks in advance
JYP
mrfrase
I think your just asking about configuration size here.
The show system resources gives you a total amount of memory available / used
Memory usage: 1024592K total, 420476K used, 604116K free
So this would show 604116K available. What this maps over to in room for configuration discriptions is unknown but it looks like quite a bit. I have no known limit numbers in this area. I have asked this question to internal engineers, If I get other infor mation look for a posting here
