09-17-2007 10:08 AM
Hi Experts,
we did a Firmware Upgrade form SAN OS 3.1.2 to 3.1.3. After the Upgrade we're no longer able to connect via SSH (Putty) to the director.
Any suggestions ?
Cheers
09-26-2007 10:24 AM
there is a bug which is fixed in 3.1(4). If you're not using RSA1 keys you might want to try "no ssh key rsa1" as a workaround from config mode...
Ralf
This is a known problem, fixed in 3.1(4)
In 3.1(4) release notes,
http://www.cisco.com/univercd/cc/td/doc/product/sn5000/mds9000/3_0/12208_07.htm#wp181946
CSCsj50299
Symptom: Following an upgrade to Cisco SAN-OS 3.1(3a), the SSH server stops working correctly if RSA1 keys are configured.
Workaround: This issue is resolved.
09-27-2007 09:38 AM
Thank you Ralf ! the workaround is resolving this issue.
