Monitoring current port group utilization
amirs
I'm searching for a way to know online (or historical) if I have an issue because port oversubscription.
Can I see the current (or historical) port group entiere bandwith?
Or maybe I should manual calculate each of the shared port utilization?
Amir
dynamoxxx
Level 5
Level 5
in device manager right click on the module and select "Check Oversubscription", then select Monitor and pick appropriate port group you want to monitor.
@dynamoxxx
But can I get this information from a command line?
I want to capture current status when I'm suspecting a problem using a script, or get historical data of this
Vu Phan
For CLI you can use the following:
Switch# show port-resources module X
ex:
switch# show port-resources module 8
Module 8
  Available dedicated buffers are 5400
 Port-Group 1
  Total bandwidth is 12.8 Gbps
  Total shared bandwidth is 12.8 Gbps
  Allocated dedicated bandwidth is 0.0 Gbps
  Interfaces in the Port-Group       B2B Credit  Bandwidth  Rate Mode
                                        Buffers     (Gbps)
  fc8/1                                      16        4.0  shared
  fc8/2                                      16        4.0  shared
  fc8/3                                      16        4.0  shared
  fc8/4                                      16        4.0  shared
  fc8/5                                      16        4.0  shared
  fc8/6                                      16        4.0  shared
 Port-Group 2
                                        Buffers     (Gbps)
  fc8/7                                      16        4.0  shared
  fc8/8                                      16        4.0  shared
  fc8/9                                      16        4.0  shared
  fc8/10                                     16        4.0  shared
  fc8/11                                     16        4.0  shared
  fc8/12                                     16        4.0  shared
 Port-Group 3
                                        Buffers     (Gbps)
  fc8/13                                     16        4.0  shared
  fc8/14                                     16        4.0  shared
  fc8/15                                     16        4.0  shared
  fc8/16                                     16        4.0  shared
  fc8/17                                     16        4.0  shared
  fc8/18                                     16        4.0  shared
 Port-Group 4
                                        Buffers     (Gbps)
  fc8/19                                     16        4.0  shared
  fc8/20                                     16        4.0  shared
  fc8/21                                     16        4.0  shared
  fc8/22                                     16        4.0  shared
  fc8/23                                     16        4.0  shared
  fc8/24                                     16        4.0  shared
You can also use the command “switch# show interface counters brief”
to determine the traffic at a 5 minute interval and determine the available
bandwidth  between the oversubscribed ports.
switch#  sho interface counter br  ------------------------------------------------------------------------------- Interface          Input (rate is 5 min avg)      Output (rate is 5 min avg)                    -----------------------------  -----------------------------                    Rate     Total                 Rate     Total                    MB/s     Frames                MB/s     Frames ------------------------------------------------------------------------------- fc1/1              0        536                   0        564 fc1/2              0        441084                0        479201 fc1/3              0        114358                0        116571 fc1/4              0        545                   0        16 fc1/5              0        15                    0        15 fc1/6              0        10205                 0        10205 fc1/7              0        35196                 0        35707 fc1/8              0        137                   0        140 fc1/9              0        541481                0        972228 fc1/10             0        222666                0        19803 fc1/11             0        218971                0        17802 fc1/12             0        45610                 0        45727 fc1/13             0        74                    0        48 fc1/14             0        135                   0        43 fc1/15             0        1                     0        1 fc1/16             0        1                     0        1 fc1/17             0        1                     0        1 fc1/18             0        1                     0        1 fc2/1              0        1                     0        1
GigabitEthernet1/1     0        2                 0        1
GigabitEthernet1/1.101 0        2                 0        1
GigabitEthernet1/2     0        0                 0        0
GigabitEthernet1/3     0        0                 0        0
GigabitEthernet1/4     0        0                 0        0
GigabitEthernet9/1     0        0                 0        0
GigabitEthernet9/2     0        0                 0        0
GigabitEthernet9/3     0        0                 0        0
GigabitEthernet9/4     0        0                 0        0
iscsi1/1           0        0                     0        0
iscsi1/2           0        0                     0        0
iscsi1/3           0        0                     0        0
iscsi1/4           0        0                     0        0
Interface              Input                          Output
                  pkt         bytes              pkt         bytes
vsan1              0          0                   6          384
port-channel 1     0        35497                 0        36011
port-channel 2     0        987423                0        1014264
port-channel 128   0        46025                 0        46024
switch#
Is there a command to see the actual usage of a port group ?
