Moving to two fabric's
user_4444
We have one Fabric with one 9509 here & another at the remote site. I want to bring the remote 9509 here and then put two 9216I at the remote site and then spilt the one fabric into two.
My question is, what would I have to do to the remote 9509, when I set it up on the new fabric? We don't use Enhanced zoning if that helps? We spilt the hosts via Vsan's, so two logical fabric's.
Thanks.
inch
Level 3
Level 3
G'day,
Besides cabling up every host's second path to the new switch and then cabling up your storage arrays, tape libraries etc. You will need to assign ports to a VSAN (or use dynamic VSAN's) and then zone hosts to storage.
Would it be worth scrubbing the config on the Remote MDS and starting again or just amending what I have?
G'day,
You wouldn't have to but it might be a good opportunity to upgrade the version of SANos on the the second 9509 and it couldn't hurt to start from scratch.
If you or any team members have not configured a switch from scratch you/they should do it :-)
Cheers
Andrew
