03-28-2012 06:30 AM
I'm new to the SAN/FC technology. I have a 5548UP which will have 2 NetApp filers and a couple of servers with FC cards connected to it. No FC traffic will leave this 5548 switch as we are just running FC to backup SAN data. I have the storage license installed on the 5548. I don't have an expansion card, so am using ports 28-32 as FC ports. I configured the switch with slot1/port 28-32 type fc and rebooted it. When the switch came up, I don't see those ports anywhere. What am I missing? I expected the ports to be FC interface.
Solved! Go to Solution.
03-28-2012 07:22 AM
The feature fcoe needs to be enabled before the FC features are available. As soon as you type "feature fcoe" you should see a storage license get checked out and FC plug-ins loaded. Then type "show int brief" and the FC interfaces should be at the top of the list.
03-28-2012 07:22 AM
03-28-2012 07:32 AM
Thanks Jeremy, that did it. I didn't think feature fcoe was needed as I was using native fc.
