N9k 93180YC-FX as NPIV Switch SAN
Networker0
i have a question, can we replace Nexus 5548 which acts as NPIV SAN switch, with another switch Nexus 93180YC-Fx with NX-OS version 9.3(5) and ACI-STRG license, I want to know if the nexus 9k can provide the same functionality (NPIV, foce ) that offered by the nexus 5548.
thanks
balaji.bandi
93180YC-FX switches only support NPV mode today, no native FC/FCoE switching with NPIV feature. You will have to use MDS switch for zoning purpose (NPIV feature enabled).
But when activating FCoE feature and binding Vfc to physical interfaces toward an initiator (UCS) according to this reference, it works:
https://www.cisco.com/c/en/us/td/docs/switches/datacenter/nexus9000/sw/93x/san_switching/configuration/guide/b-cisco-nexus-9000-nx-os-san-switching-configuration-guide-933/b-cisco-nexus-9000-nx-os-san-switching-configuration-guide-933_chapter_01111.h...
NX9K-B-SW1# show flogi database
INTERFACE            VSAN     FCID          PORT NAME              NODE NAME
fc1/1                1011   0x710020  20:08:00:0e:11:12:12:f2 20:07:00:0e:11:12:
12:f2
fc1/3                1011   0x710040  20:02:00:0e:11:12:12:f2 20:01:00:0e:11:12:
12:f2
vfc1/24              1011   0x710000  22:b8:00:3a:9c:a0:11:ff 23:f3:00:3a:9c:a0:
11:c1
vfc1/24              1011   0x710001  20:00:00:25:b5:27:1a:01 20:00:00:25:b5:27:
10:08
vfc1/24              1011   0x710002  20:00:00:25:b5:27:1a:02 20:00:00:25:b5:27:
10:07
Total number of flogi = 5.
NX9K-B-SW1# show interface vf
vfc                vfc-port-channel
NX9K-B-SW1# show interface vfc1/24
vfc1/24 is trunking (Not all VSANs UP on the trunk)
    Bound interface is Ethernet1/24
    Hardware is Ethernet
    Port WWN is 20:18:b0:c5:3c:05:d5:00
    Admin port mode is F, trunk mode is on
    snmp link state traps are enabled
    Port mode is TF
    Port vsan is 1011
    Operating Speed is 10 Gbps
    Admin Speed is auto
    Trunk vsans (admin allowed and active) (1,1011)
    Trunk vsans (up)                       (1011)
    Trunk vsans (isolated)                 ()
    Trunk vsans (initializing)             (1)
    41 fcoe in packets
    4576 fcoe in octets
    0 fcoe out packets
    0 fcoe out octets
    Interface last changed at Fri Jan  8 23:53:02 2021
However, it's not working with netapp FAS2620:
(we noticed that Po212 is sending traffic out to NetApp but no 'in traffic')
vfc-po212 is trunking (Not all VSANs UP on the trunk)
    Bound interface is port-channel212
    Port WWN is 25:e5:b0:c5:3c:05:d5:00
    Port mode is TF
    Port vsan is 1011
    Admin Speed is auto
    Trunk vsans (up)                       ()
    Trunk vsans (initializing)             (1,1011)
    0 fcoe in packets
    0 fcoe in octets
    9101 fcoe out packets
    1833094 fcoe out octets
    Interface last changed at Sat Jan  9 01:18:30 2021
Any solutions plz.
vladani
Hi Bhavin,
so you were able to do zoning, FCoE and everyting as on 5Ks?
Did it work on the end?
