Bookmark
Subscribe
4974
Nexus 5500 iSCSI QoS limitations
baracus11
There are some limitations regarding QoS on the Nexus Fabric Extenders. One big limitation is that they currently cannot mark packets or qos-groups using ACL's or DSCP. As far as I know, on FEX ports you can only mark ALL packets w/ a COS value or trust that they are already marked correctly?? We have an iSCSI environment that will have iSCSI hosts on the 5k's as well as the 2248TP's. Below is what I have come up w/ for QoS to prioritize the iSCSI traffic. Please let me know if you see any problems or areas for improvement.
ip access-list ISCSI-ACL
  10 permit tcp any any eq 860
  20 permit tcp any any eq 3260
class-map type qos match-all COS5-CMAP
  match cos 5
class-map type qos match-all ISCSI-CMAP
  match access-group name ISCSI-ACL
class-map type queuing GRP5-Q-CMAP
  match qos-group 5
policy-map type qos ISCSI-PMAP
  class ISCSI-CMAP
    set qos-group 5
  class class-default
    set qos-group 0
policy-map type qos GLOBAL-01-PMAP
  class COS5-CMAP
    set qos-group 5
  class class-default
    set qos-group 0
policy-map type queuing GLOBAL-01-IN-Q-PMAP
  class type queuing GRP5-Q-CMAP
    bandwidth percent 50
  class type queuing class-default
policy-map type queuing GLOBAL-01-OUT-Q-PMAP
class-map type network-qos GRP5-NQ-CMAP
  match qos-group 5
policy-map type network-qos GLOBAL-01-NQ-PMAP
  class type network-qos GRP5-NQ-CMAP
    pause no-drop
    mtu 9216
  class type network-qos class-default
    multicast-optimize
system qos
  service-policy type queuing input GLOBAL-01-IN-Q-PMAP
  service-policy type queuing output GLOBAL-01-OUT-Q-PMAP
  service-policy type qos input GLOBAL-01-PMAP
  service-policy type network-qos GLOBAL-01-NQ-PMAP
5K-INTERFACE:
interface Ethernet1/5
  service-policy type qos input ISCSI-PMAP
2K-INTERFACE:
interface Ethernet100/1/1
  untagged cos 5
Prashanth Krishnappa
From a configuration perspective it look ok. But any reason you are using no-drop for iSCSI which is TCP traffic?
no-drop for TCP can cause problems when there is a resource/buffer contention. TCP flow control(sliding window) should be sufficient in my opinion. But if you are experiencing problems due to packet drops etc, I would suggest that be
investigated first before implementing no-drop class for TCP.
Is pause no-drop not something that should be deployed for iSCSI traffic? I've seen a few examples with Nexus 5000s shown using a no-drop class for iSCSI and thought it probably makes sense to use for this traffic.
Mike
Gustavo Novais
Hello, picking from your config, I have a similar issue, but with FCoE traffic in the mix.
Some of the interfaces attached to Nexus switch iscsi, but others switch FCoE, never both. I'd like to apply a service policy per interface depending on the traffic they switch
What I've found out on 5.2.1N1 is that even if specifying a different queuing policy and applying it to the interface, the interface will keep the system QoS queuing policy.
I'd like that on interface A (iscsi - qos group 4) i have 50% BW for iscsi, and 50% class default and on interface B (fcoe qos-group 2) I have 50% FCoE and 50% class default.
I've defined two queuing policies besides the one applied to system qos, to provide those values, but they just got ignored...
Is this normal behaviour? I was under the impression that interface specific policies would override system qos ones...
The temporary workaround was to define a single system QoS policy with 40% iscsi, 40%FcoE and 20% for the rest...
Thanks for any insight
Gustavo
