CFS and Zone Distribution NX-OS 6.2(1) MDS9500
ndavis2001
Hello all!
Ihave a question. My SAN layout is configured of 4 switches (2 remote/2 local).
Fabric A:
Switch1   <-------  DWDM  -------- > Switch 3
Fabric B:
Switch 2 <-------  DWDM ---------> Switch 4
I made a change to the Call Home feature on switch 1, however it sent the contact infor and everything to switch 3. I am not the contact person for switches 3 & 4.
My question is this:  If I turn off CFS, will it interfere with the zoneset distribution?  I need the switches to be aware of the zones in both fabrics.
Any help is appreciated.
Nathan
dakester,
Thank you for your response. That ahs definitely helped me. I disabled CFS using your suggestion.  However, when I did I saw that the callhome was still under CFS control (device manager said that CFS was still enabled).  Thus I found the distribute command under the callhome section. I executed the following commands:
conf t
calhome
no distruibute
ctrl-z
That helped me completely remove the callhome feature from CFS control.
Thank you for putting me onto that path!
Nathan
