Nexus 6000 Interoperability Matrix with Brocade switch, any idea??
aansatosorigin
Hi Experts and Colleagues,
I'm seriously in immense curiosity about the interoprability matrix of Nexus 6000 series with Brocade DXC and 8510 using FCOE and FC connection.
I didn't find any reference about this even on Cisco website, I just find interoperability matrix for Cisco Nexus 5500 as following link:
http://www.cisco.com/en/US/docs/switches/datacenter/mds9000/interoperability/matrix/Matrix7a.html
Any idea where I can find the similar guides for Nexus 6000 series?? Really appreciate your help!
Fendy
jensmahnke
Level 5
Level 5
Hi Fendy,
I think, you will not find an Interop Matrix for the Nexus 6000 in the moment. There are no native FC ports available. If I understand this correct, there is a unified port LEM for the 6004 in the roadmap for the second half of the year. But you have to wait for native FC connection to interop with a Brocade DCX.
Cheers,
Jens
Two modular form factor chassis with multiple Fibre Channel port and special-purpose blades give you flexible deployment options. And with non-disruptive hot-pluggable components and a no-single-point-of-failure design, this device is truly the backbone of your storage infrastructure.
Maximize your options, increase reliability: The Brocade DCX 8510 Backbone offers flexibility in deployment, pricing, and add-ons. With no single point of failure and non-disruptive hot-pluggable components, your business data flies non-stop to your applications.
Simplify scale-out: Networks must support rapid growth and change in server and storage infrastructure. With scalable connectivity and high-density chassis design, the Brocade DCX 8510 Backbones reduce complexity and cost with a smaller footprint.
Streamline management, profit from robust network analytics: Get the visibility and insight you need — and make network administrators’ lives easier. Address problems before they impact operations. Maximize application performance. Reduce costs and extend Brocade Gen 5 Fibre Channel with Brocade Fabric Vision technology.
