Nexus 9372PX boot fail on Loader
ted_wen
Dear All :
       I'm recovering the Nexus 9372PX from "Loader " mode . But after finished upload the nx-os . It's prompt the image signature verification failed . I had verify the image checksum was correct . But still fail .
       Does anyone meet this error before ?
Ted Wen.
2 Accepted Solutions
Thanks you all information .
I'm using older nx-os to boot . It's work .
I had recovery this problem .
Thanks Ricky1776 and thanks all ~
Ted Wen,
6 Replies 6
Rick1776
Level 5
Level 5
Did you use the “install all” command? If not you’ll need to because it doesn’t have a kickstart image. This could be why it’s failing.
Ted Wen,
No problem at all, glad you were able to get it working.
HI Rick/Folks,
 I also get the same failure when i downloaded the recent image 9.2.3/701 image.
https://software.cisco.com/download/home/285956855/type/282088129/release/9.2(3)
Can you  please share the older image path that I could try? thanks
Filesystem type is tftp, using whole disk
.....................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................Image valid
Image Signature Verification Failed.
Boot failed
Error 9: Unknown boot failure
