Nexus IOS to support Cisco MDS 8Gb Fabric Switch for HP c-Class BladeSystem
vinayjaiswal
Level 3
Level 3
Hi Guys,
I wanted to update nexus 5k (5596UP) with latest IOS version, I checked on Cisco.com  7.1(4)N1(1) recommended version is available but as per cisco document it will not support to Cisco MDS 8Gb Fabric Switch for HP c-Class BladeSystem.
Cisco MDS 9148 switch, Cisco MDS 8Gb Fabric Switch for HP c-Class BladeSystem
6.2(21), 6.2(19), 6.2(17), 6.2(15), 6.2(13b), 6.2(13a), 6.2(13), 6.2(11c), 6.2.(11b), 6.2(11), 6.2(9b), 6.2(9a), 6.2(9), 6.2(7), 6.2(5a), 6.2(5), 6.2(3), 6.2(1)
5.2(8h), 5.2(8(8e), 5.2(8d), 5.2(8c), 5.2(8b), 5.2(8a), 5.2(8), 5.2(6b), 5.2(6a), 5.2(6), 5.2(2d), 5.2(2a), 5.2(2), 5.2(1)
5.0(8), 5.0(7), 5.0(4d), 5.0(4c), 5.0(4b), 5.0(4), 5.0(1a)
We also have Brocade 5480 (HP virtual connect 8gb 24 port fc module for c class blades system)
Pls suggest compatible version, Many Thanks.
Vijay
vinayjaiswal
Level 3
Level 3
Hi ,
I fogot to mentioned running version i.e 6.0(2)N1(2)
jkilleda
Level 3
Level 3
Hello Vinay,
You can refer to the compatibility matrix given in the below link.
https://www.cisco.com/c/en/us/td/docs/switches/datacenter/mds9000/interoperability/matrix/intmatrx/Matrix5.pdf
