No FCoE Login / Nexus 5K
rebert
Hi all
We have a problem with FcoE connection from the HP7000 Encosure with Passtru-Moduls (Emulex OneConnect CNA) connected to a Nexus 5548.
VFC interface status is still initializing
tpixxc# sh int vfc 1
vfc1 is trunking (Not all VSANs UP on the trunk)
Bound interface is Ethernet102/1/15
Port description is tpixxc-hvcm33-ENC59/Bay15, vfc1
Hardware is Virtual Fibre Channel
Port WWN is 20:00:00:05:73:ee:ae:3f
Admin port mode is F, trunk mode is on
snmp link state traps are enabled
Port mode is TF
Port vsan is 1300
Trunk vsans (admin allowed and active) (1,1000,1300)
Trunk vsans (up)                      ()
Trunk vsans (isolated)                ()
Trunk vsans (initializing)            (1,1000,1300)
1 minute input rate 0 bits/sec, 0 bytes/sec, 0 frames/sec
1 minute output rate 0 bits/sec, 0 bytes/sec, 0 frames/sec
0 frames input, 0 bytes
0 discards, 0 errors
0 frames output, 0 bytes
last clearing of "show interface" counters never
Interface last changed at Fri Nov 25 13:17:30 2011
It seems that the FIP Prozess not work proper.
QoS should be ok.
Here the FCoE configuration:
vlan 1402
fcoe vsan 1300
name liehfc-Fabric_D_Accesszone
vsan database
vsan 1000 name "Infrastruktur"
vsan 1300 name "Accesszone"
interface vfc1
bind interface Ethernet101/1/31
switchport description tpixyc-hvcm33-ENC59/Bay15, vfc1
no shutdown
vsan database
vsan 1300 interface vfc1
vsan 1000 interface san-port-channel 53
interface Ethernet102/1/15
description tpixxc-hvcm33-ENC59/Bay15, vfc1
no cdp enable
switchport mode trunk
switchport trunk native vlan 2444
switchport trunk allowed vlan 1402,2444,3790
spanning-tree port type edge trunk
no snmp trap link-status
service-policy type qos input PM-QOS-EDGE
any idea ?
Thanks for help
morinack64
Level 4
Level 4
Are there other devices already operating via FCoE on the same 5K?
What is in your service-policy on the interface, and have you tried it without the policy?
(You may also want to bind the VFC to the physical interface in your config.)
Brian
Hi Rebert,
         what is the firmware that you are using? I am seeing similar issue in my environment with version
5.0(3)N2(2)
Raj
dynamoxxx
Level 5
Level 5
we had issues with some devices would not login until we set qos policy
http://brasstacksblog.typepad.com/brass-tacks/2011/01/fcoe-login-failure-when-connecting-to-nexus-5548.html
@dynamoxxx
Prashanth Krishnappa
Do you have any servers which are not in HPC7000 which are FLOGIed in fine? Have you made sure that server in HP chassis is sending Fabric Logins? Also, since there would be muliple logins to one vFC, you will need "feature npiv" enabled on the N5k.
