11-21-2007 04:27 AM
hello
is it disruptive for the Entire Fabric
when you enable npiv feature ?
do we need to first stop all servers attached to MDS ?
let me know
thanks
JYP
11-21-2007 10:56 AM
This is taken from the 3.X configuration guide -
http://www.cisco.com/en/US/products/ps5989/products_configuration_guide_chapter09186a008089f988.html
"Configuring NPV
When you enable NPV, your system configuration is erased and the system is rebooted with NPV mode enabled. "
So this is a disruptive change. I would recommend quiesing either the A or B fabric, then affecting the changes on the downed fabric. Then bring your A fabric back online, and repeat with your B fabric. If you only have a single fabric, then you need a system wide down time.
If you found this helpful, please rate it
-- Colin McNamara
11-21-2007 01:52 PM
Careful !
NPV mode and enabling NPIV are two different things.
NPV puts a switch / module into an Intelligent passthru mode, i.e. HBA's attached to some ports passed thru an NPV port and presented to a switch as an NPIV host.
Enabling NPIV on a switch or VSAN enables that switch to recognise the NPIV hosts being present thru an NPV port.
So Yes, enabling NPV mode on a switch is most certainly disruptive, as the entire way the switch works changes.
Enabling NPIV on a switch to allow connection of NPIV hosts is not as big Change.
i.e. the Switch remains a switch, but now knows how to handle NPIV.
I have just issued, 'con t', 'npiv enable' on my switch and it did not cause any disruption.
