NPIV -We aren't able to activate .
fb_webuser
Level 6
Level 6
Hello , we have a 9124 (release 1.3.2.) and we need to activate NPIV . We use this switch with Falconstor software( NSS),2 server dell .We aren't able to work with Virtual ports of Cisco.
Thanks Pasquale
Posted by WebUser Pasquale Troisi from Cisco Support Community App
fb_webuser
Level 6
Level 6
You must globally enable NPIV for all VSANs on the MDS switch to allow the NPIV-enabled applications to use multiple N port identifiers.
Note All of the N port identifiers are allocated in the same VSAN
Enable NPIV mode on the NPV core switch:
switch(config)# npiv enable
switch (config)#
enabling NPIV on the core switch is non-disruptive. DO NOT CONFUSE THIS WITH ENABLING NPV MODE on a switch.
Posted by WebUser Adriaan Steyn from Cisco Support Community App
fb_webuser
Level 6
Level 6
We have done:switch1#config t switch1(config)#enable npiv
We have done but the switch ports show only the wwpn of the HBA
of host connected and not virtual ports fffffffooof host connect
hhhphisical ports of the HBA
switch1 # config t
switch1 (config) # enable npiv
However the switch ports still show only the WWPN of the HBA physical ports connected hosts, and even virtual ones nn (NPIV feature does just that — enables the visibility of virtual HBA ports).
switch1 # config t
switch1 #
switch1 # config t
However the switch ports still show only the WWPN of the HBA physical ports connected hosts, and even virtual ones nn (NPIV feature does just that — enables the visibility of virtual HBA ports).config t
switch1 # config t
switch1 # config t
fb_webuser
Level 6
Level 6
switch1 # config t
