Bookmark
Subscribe
637
NSS 324 Wordpress upgrade Help...
bjohnson
I have the default Wordpress .pkg running on my NSS 324.  It tells me that version 3.1 is available.  When I select to update, it downloads the 3.1 zip file, but errors out on the install.  Does this install support updating?  Is there an easy way to overwrite the install with the contents of the zip?
Thanks.
EDIT:  I only have the ability to write over the files of the wordpress install if I use the "Web File Manager" Application.  When I ftp in, I cannot overwrite the files.  I am FTP'ing on the same network.  Why are the directories greyed out in "Share Folders"??
krisscringle1
I have exactly the same issue.  Limited file access to wordpress sub folders....therefore cant upgrade
Has this been resolved?
