Query on Cisco Breakout Cable
msingh08
I have an opportunity to sell an IBM V5030 device, which is required to connect to a Cisco Chasis by means of a 6324 switch integrated into the chasis. The connection is required by means of a cable "40GBASE-CR4 QSFP + to four 10GBASE-CU SFP + direct attach breakout cable assembly, 3-meter passive".
My question is to know, is there any possibility to connect those 4 SFPs that come from this cable in the 10GbE ports of the V5030 storage or if it is only for exclusive use with IBM SFP.
0 Replies 0
