SNMP Traps by Nexus 5010
I (my customer) does not get SNMP Traps from the N5k when he unplugs one power supply (only logs). He gets only traps when he turns both power supplies off. If I check show snmp trap all trap entity are enabled (rmon Trap are off). NX-OS is 4.2(1)N2(1).
How he will get traps if one power supplies is off or fails?
Prashanth Krishnappa
What trap do you get when both power supplies are unplugged? Is it entity_power_status_change? I can test this next week in my lab.
Thanks for your support.
First I like to mention that the issue is when an Nexus2k behind the 5k (FEX) looses the power on one power-supply.
The trap I get if both power supplies are disconected is:
"Power Status Change Event.
The power operational status of a FRAU at entPhysicalTable index has changed to offEnvPower.
Power Admin Status: . "
4 seconds later I get than also the FRU Removal Event.
like mentioned eralier we also would like to get snmp traps when only one power supply goes down, but can't not figure out the config for that.
K.R.
Markus
