SysLog forwarding?
cdayton
After invoking the following command on a 9216i.
switch#logging server 192.168.231.99 facility local7
I'm left wondering what type of logging will get forwarded to the SysLog server.
It seems like there are numerous facilities and only the ability to forward up to 3 syslog servers.
How does one determine what type of messages will be forwarded for a specific facility? Not sure what level7 mean either.
RFM is helping either.
Thanks, Craig
cdayton
Here is the resolution to this issue. Fabric Manager is using port 514. Attempts to start a third party SysLog server failed because it was attempting to use the same port. Once the port conflict was resolved, the third party SysLog server did received several syslog messages.
